Dash Pad Removal
Old Feb 5, 2002 | 11:55 PM
wa68ranger's Avatar
wa68ranger
Dash Pad Removal
Can anyone tell me step by step how to remove the dash pad on my '68 f100 ranger. Thanks.
Old Feb 6, 2002 | 05:54 AM
dynamic's Avatar
dynamic
Dash Pad Removal
Their are several nuts under the pad, the easiest way is to remove everything from your dash. The cluster, the radio, and the glove box. then take a 3/8 deep 1/4" socket and go searching.
"speed is a matter of $$$, how much do you have???"
Old Feb 7, 2002 | 07:55 PM
oleblue70's Avatar
oleblue70
Dash Pad Removal
They are a bear!Other guy was right.The toughest ones are above the radio.The instrument cluster needs to be removed.(easy)and there is i think i counted them one time(14) nuts or so holding that on.They hold the cab on with four bolts but that dash pad aint goin anywhere
I have a fine tooth Snap-On 1/4 ratchet that works good for it.You can use a nut driver also.They break loose and can be screwed off by hand also.After all nuts are off,pull the very front forward lifting slightly,then the winsheild side will come straight up.
Dont forget the ones on the very ends by the door!
Old Feb 7, 2002 | 09:28 PM
wildpeanuts's Avatar
wildpeanuts
Post Dash Pad Removal
Hello
I had the same problom when i got my 1968 ford truck. There are about 6 or so nuts under the dash that you have to take out. If you take your glovecompartment out and run you hand up there at the top there are some stud with a nuts on them. But you have to look on both corners of the dash "behide it" and there is a nut. there the hardest to find. But if this dose not help send me an e-mail at wildpeanuts(No Email Addresses In Posts!) and i will e-mail you picture of my dash and show you where the bolt holes are.
charlie brown
Old Feb 7, 2002 | 09:57 PM
jml's Avatar
jml
Dash Pad Removal
Good luck and have patience. I am 5' 6" and had it luckier then other bigger hand people out there. Still took me awhile but all I had to take off was the heater hoses and disconnect the radio..nothing else. Still a b**** to get off. Easier to install for some reason. jim
67 1/2 ton and restored 48 f-1
http://www.48f-1.com
Old Apr 24, 2002 | 03:39 PM
ledgeclimber's Avatar
ledgeclimber
Dash Pad Removal
Old Apr 25, 2002 | 12:45 PM
ncargo9's Avatar
ncargo9
Dash Pad Removal
there was 14 nuts on mine when i pulled and replaced my dash easy once you pull radio and glove box, and speedo.
Old Apr 25, 2002 | 02:51 PM
CRJ900's Avatar
CRJ900
Dash Pad Removal
I didnt need to take my radio out. I just took the glovebox, and speedo. and i just reached all the way down.
Customcab
Dec 29, 2016 04:05 AM
vidaliaman
Sep 12, 2016 04:06 PM
papyjack
1978 - 1996 Big Bronco
15
Mar 15, 2016 11:02 AM
papyjack
Feb 28, 2016 06:02 PM
ramtoo
Aug 30, 2005 10:59 PM
