Dash pad removal
Old Feb 27, 2016 | 05:34 PM
papyjack's Avatar
papyjack
Dash pad removal
Hello fellow Ford friends,
I have a 79 bronco that is getting ready for paint. I pulled the complete interior out of the truck less the dash pad. Just wondering if the dash pad can be removed without removing the dash? if so does anyone have any step by step instructions? If not I will also need some instructions on how to remove the whole dash.
Cheers
Old Feb 27, 2016 | 05:47 PM
GM4WALLS's Avatar
GM4WALLS
Yes, there are ten nuts holding it on. Forget the size, wanna say ten MM. They are accessible from the instrument cluster hole in the dash and the glove box. You have to feel for them but there are 10.
Old Feb 27, 2016 | 06:22 PM
papyjack's Avatar
papyjack
sweet! thanks man, i guess i have to weave my fingers through all the wires to unplug the instrument cluster?
Also, i am on the fence on what to do "replace/repair" the dash pad. It has several fine typical slits (front to back) with no bulging. The top is still really straight other than the slits.
Has anyone attempted to repair the pad? maybe wrap it with some new vinyl? how about a dash pad cover- are they decent once installed? or should a guy just buy a whole replacement from one of the many suppliers?
Old Feb 27, 2016 | 07:12 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Do a advanced search and read a few threads on how to. Pretty much step by step is in the 1st link.
https://www.ford-trucks.com/forums/1...-dash-pad.html
https://www.ford-trucks.com/forums/s...rchid=19437940
Old Feb 27, 2016 | 07:50 PM
papyjack's Avatar
papyjack
thank you guys. lots of info here
cheers
Old Feb 27, 2016 | 08:49 PM
77&79F250's Avatar
77&79F250
Have you been here?https://www.ford-trucks.com/forums/1...then-some.html There might be some more helpful info.
Also have you joined your Canadian chapter yet? Alberta right? https://www.ford-trucks.com/forums/forum79/
Old Feb 28, 2016 | 06:02 PM
papyjack's Avatar
papyjack
Just researching the site - thanks for all the help and pointers. I put in a request to join the AB chapter.
Cheers
1eyedjack
May 30, 2009 06:36 PM
SAnVA
Mar 5, 2007 04:50 PM
towtruck
Mar 28, 2004 02:48 PM
maxfordfan
Aug 3, 2003 01:30 PM
amwxx
Jun 9, 2003 05:20 AM
