thermostat
Old May 9, 2002 | 10:06 AM
bikerwolfie's Avatar
bikerwolfie
thermostat
to make an engine run cooler do you increase the thermostat temp or decrease it?? i should know as many times i've had to change them.
Old May 9, 2002 | 11:06 AM
karlsd's Avatar
karlsd
thermostat
If your cooling system is working properly, putting in a lower temp stat will decrease the engine operating temp, i.e., your engine will run cooler. If the engine is overheating, however, changing to a lower temp stat will not have any effect -- you'll still overheat.
Old May 9, 2002 | 12:21 PM
Mil1ion's Avatar
Mil1ion
thermostat
>to change them.
There are many reasons for engine over-heating.
To start with> Remove the thermostat and bench test it with a pot of water on a stove and a Candy thermometer.
See if it opens at the temp that is stamped on the bottom part.
It will most lucky say 195*F
You can go as low as 180*F
If the thermostat works at the temp value >
Check the engine/ignition timing.
Then check the water pump and radiator.
Make sure you have coolant/anti-freeze > water combo.
*Not just water*
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green]Do You Need To Decode Your 78 Truck Data Plate?
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
[font color=green]Please Feel Free To Visit My Website.[/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V [/font]
Old May 9, 2002 | 12:32 PM
bikerwolfie
thermostat
it was overheating, but that was due to a straight water fill and someone had installed the thermostat backwards ( spring towards the hose). i do alot of heavy towing and in town driving and have always preferred a cooler thermostat. put a 160 in just haven't had a chance to try it out and wanted to be sure i went the right way with the temp before i did. thanks for the info.
Old May 9, 2002 | 12:40 PM
Mil1ion's Avatar
Mil1ion
thermostat
Unless you're in a Hot Climate.
160* is too low.
The engine will suffer for it.
[/font
[font color=red]
Old May 10, 2002 | 04:16 AM
bikerwolfie
thermostat
what would you recomend? i'm in north georgia and the temp here is about 90 f or hotter during the summer months. with the 160 in it runs about halfway on the stock gauge,(i have an aftermarket gauge but havent had the time to install it).
Old May 10, 2002 | 12:31 PM
Mil1ion's Avatar
Mil1ion
thermostat
Since the price is negilable,I would try a 180* first.
See how it does and go from there.
[/font
[font color=red]
Old May 10, 2002 | 08:49 PM
bikerwolfie
thermostat
i may have bigger problems than a thermostat. i installed a guage kit and found that my oil pressure is 10 psi at idle and 20 psi at 65mph. i do have freash oil and oil filther in. the truck doesn't smoke or use oil ( as far as i can tell i've only had it a few weeks and have put about 2500 miles on it). i'm hopping it's just the oil pump. anyway i picked up a new one and am giong to install it this weekend, weather premitting.
Old May 10, 2002 | 09:03 PM
fatdaddy's Avatar
fatdaddy
thermostat
Resendiz
Aug 4, 2015 02:23 AM
POPAJON
Nov 21, 2012 08:42 PM
johnno5
Feb 7, 2008 08:50 PM
Nigel
Aug 28, 2007 10:23 PM
fdels
Jun 29, 2004 02:15 AM
