Aerostar Ford Aerostar
Outer Tie rod replacement
Old Apr 24, 2006 | 11:45 AM
DeadIssue's Avatar
DeadIssue
1993 3.0L 2WD
The fact that they are almost falling off is a pretty sure sign that I should replace them, so I got a few questions.
1. Is there a certain torque spec for reinstallation?
2. Do you need a wheel alignment afterwards?(if so is there anyway to get around it.)
Im no high end auto mechanic more of a "do it yer self er" but I can do most of my own work. I was thinking that I can just screw them on as far as the old ones and it would be fine. Will that work?
Any help would be great. Thanks.
Old Apr 24, 2006 | 12:31 PM
96_4wdr's Avatar
96_4wdr
1. tie rod nut=70 lbs ft max
2. an alignment will pay for itself in far less tire wear
handling is more stable and steering is more accurate with a professional alignment
screwing in the new tie rods to same length as old tie rods will get you to the alignment shop
Old Apr 24, 2006 | 02:39 PM
DeadIssue's Avatar
DeadIssue
Thanks
Thanks for the tip.
Old Apr 25, 2006 | 04:28 AM
krankshaft's Avatar
krankshaft
The reason is basically if the tie rods are in bad shape your probably already out of alignment and adjusting the new ones that way will only make it worse.
I like to do as much work as possible myself too but I only had to kill 1 pair of tires to learn the hard and expensive way why alignments are so important.
The cost of an alignment is usually inexpensive when compared to the cost of new tires down the road due to uneven premature wear .
Old Apr 27, 2006 | 09:38 AM
DeadIssue's Avatar
DeadIssue
Yeah I totally agree, The main reason I was asking was because Im putting a new set of tires on this fall and I was going to wait for my alignment till then. I put the new tie rods on a few days ago and took it down a long stretch of road and the van seems to drive straight as an arrow even when I take my hands off the wheel. So I might take the risk of putting a little wear on the old tires...I could care less really. I'll align forsure when I get the new rubber.
Thanks for the advice.
Old Apr 29, 2006 | 08:18 AM
94FordGuy's Avatar
94FordGuy
Dont leave it too long .Changed mine with a new set of rubber last month and same as you my van drives straight as an arrow however you wouldn't believe the tire wear (inside both front).Not worth letting it go for the $80.00. it cost for an alignment.My van sees about 200 kilometers a day so I suspect that had something to do with it.Good luck
Old Apr 29, 2006 | 11:36 AM
DeadIssue's Avatar
DeadIssue
Done
Yeah The tie rod replacment went fairly well, I damn near needed a torch for the passenger side she was seized on there pretty good. Nothing my trusty 18" pipe wrench couldent take care of though.
I got one question, I took some other dudes advice and checked the ball joints while I was down there. I put one hand on top of the brake rotor and my other hand on the bottom of the brake rotor and gave it a good "back and forth" shake...and there doesent seem to be any play in the joints. It seems pretty tight. Is that the usual way to check them ? should I assume there ok?
Old Apr 30, 2006 | 06:18 AM
94FordGuy's Avatar
94FordGuy
Yep thats the the way to do it 12 o'clock and 6 o'clock position.the only thing I would add is its better to do that test with the wheel on and tightened.Another test I do is with the wheel raised a few inches off the ground put a piece of wood or long prybar under the tire and give it the up and down while checking all joints.Hope this helps
Old Apr 30, 2006 | 09:19 AM
DeadIssue's Avatar
DeadIssue
Thanks brother!
az3pqf
49
Aug 27, 2020 10:03 PM
1955effie
1983 - 2012 Ranger & B-Series
Sep 12, 2017 11:56 PM
dcelrod
Jul 23, 2015 08:44 AM
RShaips
Jul 28, 2009 08:21 AM
hancockr
24
Apr 7, 2006 09:58 AM
