Blend door actuator replacement doesn't work!
Old Jul 12, 2009 | 01:58 PM
RShaips's Avatar
RShaips
I have my daughters 2004 Explorer aprt and the blend door actuator out due to stripped gears in it. I have bought 2 replacements so far and neither one will work. I am plugging them in and they will not turn, thought i would check them before i installed them. The old one will turn when I turn the switch, both of the new ones I bought do nothing. The replacement looks the same but the plug is on the back rather than on the side. What's the deal here? I bought them at Advance Auto. I really need to get this thing back together and I really don't want to put one in that doesn't work! Thanks for youe help.
Old Jul 12, 2009 | 03:58 PM
Traxxis's Avatar
Traxxis
When you say that niether one of them work, do you mean you actually watched the actuator out of the plenum and it did not turn when you turned the ****? Or do you mean that you cant switch between hot and cold?
Check all of the fuses and relays.
Old Jul 12, 2009 | 04:28 PM
RShaips's Avatar
RShaips
The actuator did not turn when it was out of the plenum. The old one still turns but the gears are stripped.
Old Jul 12, 2009 | 05:20 PM
rrgone's Avatar
rrgone
I have seen reports that the aftermarket actuators do not work on Gen 3s. I'm not sure, but perhaps they are intended for the Gen 2s. I suggest you get a motorcraft actuator.
Old Jul 12, 2009 | 05:44 PM
RShaips's Avatar
RShaips
Thats kinda what I was thinking! I will find a Motorcraft somehwere besides the dealer, I hope. Thanks
Old Jul 18, 2009 | 03:18 PM
caseys's Avatar
caseys
Take a look on this site, there is a great instruction for fixing the blend door. When mine went bad on our '96 Explorer it was not the actual motor but the shaft part between the motor and the door that broke. If that is the case with yours, then replacing the motor will not do anything at all since the motor is not the problem.
Old Jul 19, 2009 | 10:48 PM
texan2004's Avatar
texan2004
How does the actuator turn if the gears are stripped?
Take a look at my gallery and you will see what I found in my daughter's 97 Ranger. There is a low dollar fix for the broken shaft on the blend door itself but it would not help me as you will see in the gallery.
Old Jul 28, 2009 | 08:21 AM
robert albright's Avatar
robert albright
Anyone have a step by step instruction for replacing a stripped blend door actuator on 2002, 3rd gen? I need to do the one on my wife's exploder.
dunerookie
1997 - 2003 F150
Nov 28, 2022 06:46 PM
icantdo55
Dec 25, 2019 09:46 AM
bgwho922
Jul 9, 2017 12:25 PM
danomac
1983 - 2012 Ranger & B-Series
Oct 2, 2014 08:44 PM
dilas
2004 - 2008 F150
Oct 27, 2011 06:51 AM
