Grinding starter
Old Apr 23, 2006 | 08:17 PM
Ford150/428/dud's Avatar
Ford150/428/dud
Grinding starter
Today i put the finishing touches on my engine like radiator hosses and heater hoses. Me and my dad prabley spent a half an hour getting the timing alligned right so it ran good then we shut it off. When i came back about 2 hours later and tried to start it when the startert engaged it made a loud grinding noise. Could this be the starter drive going to heck
Old Apr 23, 2006 | 09:22 PM
79f-250custom's Avatar
79f-250custom
i had the same thing happen to mine. it started then it did not disengage. now it just grinds. id just get yourself a new startor, there only 50 bux. thats what im going to do.
Mitch
Old Apr 24, 2006 | 06:42 PM
Ford150/428/dud
It just makes me mad because its a fairly new starter. Mabye 2 years old. And it just happened all of a sudden.
Old Apr 24, 2006 | 06:58 PM
79f-250custom
well before you buy yourself a new one, get you battery tested and buy a new startor celinoide.
if both of those check out then pull your startor and have it tested somwhere. they will tell you if its good or bad.
Mitch
Old Apr 24, 2006 | 10:32 PM
Mil1ion's Avatar
Mil1ion
I doubt the solenoid (correct spelling) is causing the problem and I hate spending money un-necessarily.
Make sure the battery is fully charged using a battery charger before you do any tests.
Starter drives are known to *Just go bad* without any warning.
Let's see what happens with a fully charged battery first.
Old Apr 26, 2006 | 08:05 PM
Ford150/428/dud
The battery isnt dead, When i turn the key the starter engages but it makes a grinding sound that stops when the engine starts up and a release the key.
Old Apr 26, 2006 | 10:05 PM
Mil1ion's Avatar
Mil1ion
The starter drive is hanging up and not kicking back into position.
Remove the starter.... grease the drive and shaft, put the juice to it a few times on the bench ....and re-install it.
This is a common problem for engines that sit for a while.
Quote: The battery isn't dead.
FYI, It is best to have a battery fully charged before trouble-shooting,or assuming it is something else.
If it is fully-charged when one comes here to ask questions we know the battery Isn't the problem "right from the start" as batteries cause a lot of problems when they aren't fully charged.
Too many people assume the battery is fine.
The Battery is the Heart of a vehicle.
Old Apr 28, 2006 | 11:05 PM
79f-250custom
Yes i know i cant spell. i was wayyyyyy off on that 1. hahaha
so i have the same prob with my starter. i think i may have ran the truck when it was engaged. do you think i ruined the starter? ill take it off and grease her up and see if that helps.
and how are you comming with ur starter Ford150/428/dud??? get yours turning again???
Mitch
peckerwood
6.7L Power Stroke Diesel
May 6, 2013 11:35 AM
Lukes66
Nov 19, 2010 04:39 PM
wagontrainer
Feb 22, 2008 10:34 AM
budhead1
Jan 27, 2006 04:10 PM
98XLTBeast
Oct 6, 2005 08:42 AM
