starting problems
Old Apr 16, 2006 | 03:57 PM
BugsB1976's Avatar
BugsB1976
Cool starting problems
i have a 1984 ford f-150 with a 351 windsor and everytime i try to start it all it wants to do is grind real bad and it is not the starter because i just had it rebuilt completely so what could b the problem.
Last edited by BugsB1976; Apr 16, 2006 at 03:58 PM. Reason: forgot to add something
Old Apr 16, 2006 | 04:03 PM
cujo8's Avatar
cujo8
Why did you have the starter rebuilt? Were you having problems before the rebuild of the starter? You could have a bad ring gear on your flex plate/flywheel. You could try rotate the engine by hand to get to a new location on the ring gear. I am not sure about your application, but some starters require shims to adjust the starter gear to ring gear orientation. Where there any shims on the starter when you removed the old starter?
Jim
Old Apr 16, 2006 | 04:08 PM
BugsB1976's Avatar
BugsB1976
starter problems
i had the starter rebuilt because the abendix and some of the teeth were bad and i have a 1984 ford f-150 with a 351 windsor motor but i can't figure out what to do could it b the flywheel
Old Apr 16, 2006 | 04:09 PM
BugsB1976's Avatar
BugsB1976
no there was no shims when i took the starter off
Old Apr 16, 2006 | 04:16 PM
cujo8's Avatar
cujo8
If the teeth on the starter were bad there is a good possibility that the teeth of the flywheel are bad as well. Pull the starter out and look inside to check the condition of the teeth. If you can't see it directly use a ,irror and a flash light or feel w/ your fingers. I take it this truck has a manual transmission, since you are asking about the flywheel correct?
Jim
Old Apr 16, 2006 | 04:31 PM
BugsB1976's Avatar
BugsB1976
do u have yahoo instant messenger if u do please add me to it so we can talk a lot better please my yahoo id is BugsB1976
Old Apr 16, 2006 | 04:42 PM
cujo8's Avatar
cujo8
No I do not have yahoo instant messenger on my computer. Since your truck has an automatic tranny, then you have a flexplate not a flywheel. Check the teeth on your flexplate and then you will know if that is your problem. If it is the problem you are goint to have to pull the engine to fix it. Good luck.
Jim
Old Apr 19, 2006 | 06:42 AM
cujo8's Avatar
cujo8
BugsB1976, Have you had any luck w/ your starting problem?
Jim
Old Apr 19, 2006 | 12:26 PM
BugsB1976's Avatar
BugsB1976
starter problems
yes i have i am putting another flywheel on it sometime today or tomorrow but i will keep u updated on it
Old Apr 19, 2006 | 03:44 PM
cujo8's Avatar
cujo8
So was your old flexplate/flywheel missing some teeth?
Jim
natew
Nov 16, 2015 12:22 PM
ernest russell
Apr 25, 2015 06:57 PM
daerhldgs2
Sep 29, 2008 09:57 PM
mike_23us
General Automotive Discussion
May 7, 2004 09:04 PM
tuffguy
Offroad & 4x4
Jul 25, 2000 10:33 PM
