2003 navigator starting problem
Old Mar 19, 2015 | 03:48 PM
ernest russell's Avatar
ernest russell
Question 2003 navigator starting problem
this problem just started.when i first start i hear a buzzing sound and it wont start i turn the key on and off several times then it starts i have no problems all day or acouple of days then it hapens again any answers thanks
Old Mar 19, 2015 | 06:05 PM
alloro's Avatar
alloro
The buzzing sound could be a relay. If that's the case it's probably a bad ECM.
Old Mar 20, 2015 | 06:41 AM
ernest russell
thanks Alloro
Old Mar 20, 2015 | 10:09 AM
alloro's Avatar
alloro
Originally Posted by ernest russell
thanks Alloro
Don't just run out and get another ECM, you should first look for things like loose or chewed wires, bad battery cables, etc.
Old Apr 10, 2015 | 11:02 PM
bronconvict's Avatar
bronconvict
Could be Relay, 2003 is notorious for bad Fuse Box circuitry. Far upper right relay. (little black box) located in passenger side kick panel.
Old Apr 11, 2015 | 05:57 AM
ernest russell
thank you bronconvict this warmer weather has helped to i`ll check this out
Old Apr 11, 2015 | 11:15 AM
Hamfisted's Avatar
Hamfisted
It's the classic PCM relay / fuel pump relay failure. If you open the fusebox there at the passenger kick panel, look at the top three rectangular shaped relays. The one on the top right (laying "horizontal"...) is the PCM relay. If you pull the PCM relay out and look at it's terminal base area you will probably see signs of melted plastic. You can swap those top three relays around to get it running, till you buy a spare relay to replace it, but in the end you are going to have to replace the whole fusebox to correct the problem. Since the Ford geniuses permanently soldered the weak fuelpump relay to the fusebox circuit panel, and that's what generates all the circuit heat. You can find the fusebox online for about $375 now. Supposedly the replacement fusebox is corrected for this issue. I know the relay part numbers are different, so maybe it is. I replaced my box and now keep a spare PCM relay in the glovebox just in case.
-Mike
Actual burned up fuelpump relay soldered onto circuit board of fusebox....
Old Apr 11, 2015 | 11:15 PM
ernest russell
thanks hamfisted what kind of job is to replace fuse panel
Old Apr 22, 2015 | 10:11 PM
bronconvict
Old Apr 23, 2015 | 12:00 PM
ernest russell
Bronconvict, i bought a pcm relay from auto zone no problems so far thanks for all your help
Old Apr 25, 2015 | 05:07 PM
Hamfisted's Avatar
Hamfisted
Buy an extra one to put in the glovebox as a spare. If the first one burned out the second one will too, and probably sooner rather than later. The burned PCM relay is just the symptom, the actual cause is the fuel pump micro relay on the fuse panel circuit board itself, and that requires a new fusebox. It's all plug-n-play, takes about 30 minutes to swap out fuse box.
-Mike
Old Apr 25, 2015 | 06:57 PM
ernest russell
thanks Mike will do,ill try to find another fusebox thanks for the good info
jpkinard
27
Sep 30, 2012 06:30 PM
bobmac219
1983 - 2012 Ranger & B-Series
Oct 12, 2006 05:30 AM
ptt
Jan 31, 2006 07:35 PM
LonghornOwner
Oct 5, 2004 06:45 PM
Jaken86
1978 - 1996 Big Bronco
Sep 16, 2004 08:49 PM
