ABS light stuck on
Old Apr 13, 2006 | 05:59 AM
squeals99's Avatar
squeals99
ABS light stuck on
My speedo and odometer recently went out because of a blown fuse and now that i got those working again the abs light stays on
any fixes for that?
Old Apr 13, 2006 | 09:55 AM
squeals's Avatar
squeals
anybody got an idea for this? its buggin me really bad
Old Apr 13, 2006 | 11:16 AM
JoeVB's Avatar
JoeVB
The ABS system/light is pretty simple. The only thing you really have are the ABS computer, the valve itself and then power and grounds.
If your light is on then you have power. If you haven't screwed with any other wires then your grounds are OK.
You can read this thread to see what I did to get the codes out of my ABS computer...https://www.ford-trucks.com/forums/s...d.php?t=445265
Good luck
Old Apr 13, 2006 | 02:14 PM
zemus420's Avatar
zemus420
any fixes for that?
You might want to check your ABS fuse i bet that blew out as well.
Old Apr 13, 2006 | 02:28 PM
squeals99's Avatar
squeals99
i just checked the fuse and it looked good...
gettin ready to read your thread and see if i can do anything
thanks
Old Apr 13, 2006 | 02:33 PM
squeals99's Avatar
squeals99
so in other words check the grounds that i am running off of my headlight relays? because i forgot to add that in the title... but i am in the middle of the project for hooking up headlight relays
so ill work on that and see if i get anything
thanks guys
Old Apr 13, 2006 | 02:39 PM
EgoMan's Avatar
EgoMan
I had that problem but it was because my ignition switch is so sloppy it doesnt matter if you put the door key in it will start. The only problem is If I start it with the wrong key all the lights stay on and the trasnmission doesnt shift right...lol its messed up.
Old Apr 13, 2006 | 04:10 PM
squeals99's Avatar
squeals99
my ignition is messed up too... i can pull the key out when it is on and it will drive fine and all... but i can only start it with that one key... but im gonna check and see if it has to do with a ground wire being on something else
Old Apr 13, 2006 | 05:01 PM
EgoMan's Avatar
EgoMan
Sounds like mine....give it time and it will start with all kinds of keys. Basically mine will start and all the lights are on that are on when you first hit the key. On top of that the door chime never goes off when the doors are shut so I ripped the plunder out of the door to make it stop.. lol probobly all tied into something in the colum.
Old Apr 17, 2006 | 08:53 PM
squeals99's Avatar
squeals99
well i now feel like an idiot.... i told my friend to take out my cigarette lighter fuse and put it in place of my blown speedo/odometer fuse... instead he took out the ABS fuse
so i put a fuse in it today thinking it was the cigarette lighter until i read the fuse panel and it was the ABS
BillU05
1997 - 2003 F150
16
Sep 6, 2005 12:25 PM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
RobertGordon
Mar 6, 2004 08:22 PM
haroutd
Jan 2, 2003 08:19 PM
garymulins
1978 - 1996 Big Bronco
15
Nov 30, 2002 10:38 PM
