i have a 77 f-250 crewcab 4x4 with a/c and a 4 speed manual transmission that i am swaping in a 460 that is a mild build that the engine is going to have 400+ hp out of the truck, what a aluminum rad with eletric fans be enough to cool my truck and what thermostat would work like a 160 degree or is their a different rad that with minor modafacations that would work? i would like to have a aluminum rad.
Well I run an alum radiator in my race truck, and Ivan has one in his truck both mounted in the bed of the truck with electric fans and they work great but then again the radiators both of us are running are pretty big units.
Alum radiators are more effiecent, and do a good job of cooling, but I can't give you specific part numbers that will work for your application although I know there are companies that make direct replacement alum radiators for almost every vehicle out there.
