Waterpump Plate
Old Apr 10, 2006 | 06:08 PM
pokerpuller's Avatar
pokerpuller
Waterpump Plate
When I disassembled my engine, there was a plate behind the waterpump. It was in terrible shape, corroded through. Do I need this plate?
-kit
Old Apr 11, 2006 | 09:05 AM
classic79's Avatar
classic79
yes, I believe so.
Old Apr 11, 2006 | 09:22 AM
banjopicker66's Avatar
banjopicker66
Yep. You need it.
That plate is there to direct the water flow efficiently. If the space between the impeller blades and the backside of the pump is too great, the water will simply swirl around inside, instead of flow through the pump.
Essentially, too much dead space doesn't allow the impellers to create directional suction and pressure to move the coolant.
So, you need that plate to ensure viable pumping.
