Sponsored by: Real Truck
Towing Rating
Old Mar 31, 2006 | 11:39 AM
gordon500kv's Avatar
gordon500kv
Question Towing Rating
I have a 4x4 f250 2006 with the towing system on it and heavy supension. I am wondering what the max. is I can tow. Does any one pull 5th wheels and if so how much can I safely pull on a regular basis?
Old Mar 31, 2006 | 11:47 AM
wiingnut's Avatar
wiingnut
I copied this info from a posting I answered 15 minutes ago. I hope this helps
the 350 regular cab drw with 6.0, torque shift, and 4.30 rear end will pull 19,200 lbs. , Supercab with same configuration 6.0, torque shift, 4.30 rear will pull 18,800 lbs., and crew cab with same config. to powertrain will pull 18,600lbs. Hope this helps. here's the link:
http://www.fordvehicles.com/trucks/superduty/ goto: towing capacities on left side of page good luck.
I just noticed you have a 250. Go to the link I have supplied and you should be able to find 250 specific info
Old Mar 31, 2006 | 12:01 PM
biz4two's Avatar
biz4two
Need more info on your SD.
Engine? 5.4L, 6.0L, or 6.8L (V10)
Configuration? (ie: SC SWB, CC SWB, SC LWB, CC LWB, etc)
Transmission? Auto or Stick
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
lp92chateau
British Columbia
Nov 19, 2006 02:02 PM
sla3492
Electrical Systems/Wiring
Apr 21, 2006 02:21 PM
dakota joe
Apr 13, 2006 05:43 PM
