Trans Code Interpretation
Old Apr 7, 2006 | 05:03 PM
4AVIEW's Avatar
4AVIEW
I could use some help interpreting what parts to buy based on the codes that came up when I scanned my work truck.
Problem is when I come to a stop the engine dies (1995 E4OD), I have to switch to neutral so it won't die out.
Codes come up as 632[Trans Control Switch No State Change] and 211 [Profile Ignition Pickup Erratic]
There is no "Trans Control Switch" for my truck, there a Trans Control Solenoid though
What parts would you recommend getting?
Thanks for your help
Old Apr 8, 2006 | 07:28 AM
Casey's Avatar
Casey
The trans control switch is the overdrive off button on the end of the shifter. If you don't press this button when self test is running you will get that code.
Neither of those codes is causing your problem. Your torque converter is not unlocking when it should.
Things to check:
Low trans fluid.
Loose internal filter.
Bad torque converter control solenoid.
Stuck valve in the valve body.
Bad torque converter.
Worn pump.
Old Apr 8, 2006 | 06:45 PM
4AVIEW's Avatar
4AVIEW
Thanks for your tips, oddly enough...my other truck's (in my avatar) brand new tranny has the similar problem with the T.C. locking when I put it in reverse so I know what it feels like. Plus I get a code indicating the T.C. has locked up. The prob with my work truck is a little more strange. For instance, when I approach a stop sign, I can slow down to walking speed and its fine, but the very second I have no forward movement it dies fast. If I keep the gas and the brake on it works like it should. Also, the speedometer is flickering high/lo (+- 30mph) at just about any speed.
This prob is driving me crazy, and the auto shops just want to scan the computer and not do any hands on troubleshooting.
Would the Torque Convert Solenoid and the Transmission Control Solenoid be the same thing on my tranny perhaps? That sounds like something to change just to see what happens .
Old Apr 9, 2006 | 08:00 AM
Casey's Avatar
Casey
No, they are not the same because there is no such thing as a transmission control solenoid. Reread my post above.
Green96
Jul 13, 2020 10:34 AM
crowncrazy87
1997 - 2003 F150
May 20, 2016 08:08 AM
Nathan511
Feb 29, 2016 07:56 AM
cutlass
Aug 4, 2013 04:15 PM
boxdoc2
Sep 4, 2006 08:56 AM
