Need code interpretation!!
Old Sep 2, 2006 | 09:46 PM
boxdoc2's Avatar
boxdoc2
OK, I did the search and found the explanation of the code. Wanted to get some thoughts on these results:
Advance Auto Parts
Vehicle Scanned
Global OBDII
Vehicle
P0453
EVAP Emission
Control System
Pres Sensor High
DTC Pending (Codes)
No Faults Detected.
So I did a search here for the P0453. It's "Fuel tank pressure signal circuit input above maximum". What the heck is that?
Thanks for any help!!!
Mike
Old Sep 2, 2006 | 10:29 PM
bridge's Avatar
bridge
Sick 'n Tired
Basically means a damaged Fuel Tank Pressure (FTP) sensor or a short somewhere in the circuit.
Old Sep 3, 2006 | 09:24 PM
boxdoc2's Avatar
boxdoc2
Could it be as simple as replacing the old gas cap with a new one? I'm sure the one on there is original. It was a suggestion by someone else. Thoughts?
Old Sep 3, 2006 | 10:30 PM
BowTieHatr's Avatar
BowTieHatr
usaully a gas cap problem you have a p0455 gross leak. by any chance you filled up with the truck running or been over filling your fuel tank?
Old Sep 4, 2006 | 12:51 AM
boxdoc2's Avatar
boxdoc2
Very doubtful. I never leave it running when fueling. I top it off, but I don't know that I've over filled it.
Where would this pressure sensor be located? I can't seem to find any more information on it.
Thanks for the help!
Old Sep 4, 2006 | 08:56 AM
projectSHO89's Avatar
projectSHO89
The FTP sensor is located on the top of the fuel tank, perhaps part of the pump module assy, perhaps a separate sensor.
I haven't dropped the tank on my F150, but on my Contour, it's a separate sensor.
The PCED has a diagnostic procedure for loaciting the fault, requires a scan tool that can read PIDs.
Steve
rexpedition99
29
Mar 28, 2017 04:12 PM
nitro94
1997 - 2003 F150
Dec 27, 2014 05:27 PM
vtgboss
Aug 29, 2014 07:46 AM
FullOutPwr
Oct 12, 2010 10:49 PM
