Need some o-ring help!
Old Apr 5, 2006 | 09:46 PM
DavidT.'s Avatar
DavidT.
Originally Posted by Kwikkordead
I'm positive that you can silicone that housing and it will hold. Just don't be a cake decorator. Use just enough to fill the groove and a tiny bit more. Let it cure for the night and put it back on in the morning and you'll be good to go.
I agree with kwik. If worse comes to worse, the silicone will work fine. I use Permatex The Right Stuff Gasket Maker silicone for many o-ring applications (On various cars) that were hard to find and never had a problem. You wouldn't believe how great that stuff seals once it hardens.
Old Apr 5, 2006 | 10:52 PM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by tjbeggs
no put the two halves together while the silcone is fresh. then let it set so the silicone doesn't blow out
Yes. Sorry about that Strokin_it, I should have been more clear. Put it together immediatly after you apply the silicone.
Make sure that the two mating surfaces are oil free.
Old Apr 6, 2006 | 01:20 AM
jtharvey's Avatar
jtharvey
I too checked with Ford for that o-ring and came up with the same result - no individual parts sold for the turbo. I wonder if you could get it from International or possibly from Garrett (turbo guys, not BCDP)?
Old Apr 6, 2006 | 06:02 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
nah, i need it today. last night i wirewheeled it, so i have to clean it and maybe walnutshell-blast the housings and then clean them very well and then put the right stuff in. so iguess i need to put the actual backplate and wheel on, and have that as the last thing to do, correct?
Old Apr 6, 2006 | 07:13 AM
Kwikkordead
Yes, that is the final step before reinstalling the housing.
cjcocn
16
May 17, 2009 04:11 PM
F350-6
36
Mar 22, 2008 11:19 PM
bdrummonds
36
Mar 8, 2008 10:05 PM
99 7.3 towrig
Mar 2, 2007 11:22 PM
mitch_c
Oct 10, 2006 07:49 AM
