2barrel carb on 4-barrel intake
will i be alright with the 2150 on a edelbrock 4barrel intake its 351m.
i cant get the holley to be consistant and when it runs good it suck the heck out of gas .
it will be just fine with the adapter....youl love the mtrcraft 2bbl, one of the simplest and best carbs around
What intake are you using? If you have a 2-hole intake, you can use a good (not Mr. Gasket) two to 4BBL adaptor, but if you have a four hole intake, you're just setting yourself up for a major headache.
its just a 2 hole intake, ive found out about the mr. gasket adapters and i dont want to go edelbrock because its on an off road truck. thanks for the help.
edit will this work. 720-1933 @ jegs.com
run a q-jet, they are just as good offroad as the mtrcraft....but you will have teh benifits of a 4bbl as well
for an adapter, try sum-g1406, or trd-2065, or mor-64966
those are part #'s from summit
ok i got the 2150 on but where the heck does the vacume advance and the pcv valve hose go.
hopefully the only 2 vacume lines in need besides the booster wich i have hooked on the manifold.
completly off topic but how many miles should i put on my motor before i take it to the woods.
thanks
matt
thanks
matt
ok just alittle update i got the 2150 on there and drove it a few days and it started to pour fuel out of the throtle plate shaft and i missed the 4barrel power now im working on the quadra-jet but i lost all fire. its only firing when i let off the key switch and it has 10-11 volts at the coil. so i dont know ..... key switch???
anyway thanks for all the help.
Jag Red 54
11-06-2014 01:48 PM
4t6ford
01-26-2005 10:33 AM
