Headliner removal help E350
Old Mar 31, 2006 | 09:13 AM
rwetter's Avatar
rwetter
Is there a tool to help remove the plastic tabs that hold up the headliner? I would guess that it would look like a small forked crowbar.
I want to pull the headliner to insulate the roof, and I am very good at busting the tabs when I try, so any suggestions would be helpful!
Old Mar 31, 2006 | 12:16 PM
Andre`'s Avatar
Andre`
Just be diligent. Pry enough with a flathead screw driver to get you fingers and/or pliers all the way under. Then, just wiggle/twist as you pull down. Use more twisting/wiggling than force until you get it out 1/2 an inch or so. Then, the rest is easy. If you want to get fancy, you could probably make your own tool by taking a sturdy fork and bending/breaking or cutting off the middle two forks. I've removed lots of these w/o breaking any. If it's cold when you're doing it, you may want to be more careful, or get the interior warmer. Good luck.
Old Mar 31, 2006 | 12:34 PM
someday's Avatar
someday
i know ive seen them before at autozone or advance...it wouldnt hurt to go and personally go over their tool section
Old Mar 31, 2006 | 09:42 PM
rwetter's Avatar
rwetter
Thanks for the thoughts, I have about a 90% unbroken removal rate in the past, but can always use another tool!
I'll start checking the supply stores....
Old Apr 3, 2006 | 07:31 PM
rwetter's Avatar
rwetter
Sure enough Autozone had the tool! took a few of the employees to brainstorm before they found it but all is well!
Old Apr 3, 2006 | 09:58 PM
someday's Avatar
someday
how did the tool work out?...i am interested to find out if u find any wiring for an overhead console or the fancy rearview mirror...i have an 05 cutaway and would have ordered that if i could...i would like to have at least the rearview with compass, temp, and homelink
Old Apr 4, 2006 | 02:28 PM
rwetter's Avatar
rwetter
Tool works great.
Sadly no extra wires to be found so far...
...Yea I finally past 50 posts...!!!
Old Apr 15, 2006 | 11:52 AM
kmac1967's Avatar
kmac1967
I am looking for Ford installation instructions for the accessory rearview mirror with temp, compass and homelink for a 2003 f-250.
LeviD
19
Oct 20, 2018 09:30 AM
KellerMAC
13
Oct 16, 2015 06:47 PM
The_Punisher
Apr 14, 2012 10:29 PM
user1022
Mar 11, 2010 10:41 PM
bluegreen
Jun 30, 2006 06:59 AM
