Headliner Removal
Old Dec 5, 2011 | 07:46 AM
KellerMAC's Avatar
KellerMAC
Headliner Removal
Does anyone have pictures or video of a headliner removal of a 2001 F250? I need to remove mine and before I start I would love some guidance if possible.
Thanks
KellerMAC
Old Dec 5, 2011 | 08:33 AM
mueckster's Avatar
mueckster
What cab configuration do you have?
Old Dec 5, 2011 | 08:54 AM
KellerMAC's Avatar
KellerMAC
I have a the Lariat 4X4 interior with the small console that displays temp/miles to empty/etc.
Old Dec 5, 2011 | 09:03 AM
mueckster's Avatar
mueckster
Regular Cab, Super, or Crew?
Old Dec 5, 2011 | 09:09 AM
KellerMAC's Avatar
KellerMAC
My truck is a Crew Cab
Old Dec 5, 2011 | 09:12 AM
mueckster's Avatar
mueckster
I gotta run, but I can post some pics from my dvd manual tonight.
Headliner —Crew Cab
Removal and Installation
Remove the rear window. For additional information, refer to Section 501-11 .
If equipped, remove the overhead console.
Release the locking tabs while pulling down.
Remove the left and right visors.
Disconnect the electrical connectors.
Remove the left and right visor arm clips.
Position the left and right front door opening weatherstrips down from the headliner.
Remove the left and right windshield side garnish moulding. For additional information, refer to Moulding—Windshield Side Garnish in this section.
Remove rear B-pillar assist handles.
Remove the four covers (two on each handle).
Remove the two B-pillar assist handles.
Remove the four screws (two on each handle).
If equipped, remove the rear and front passenger assist handles.
Remove the covers and screws.
Remove the rear assist handles.
Remove the left and right rear coat hooks.
Remove the two courtesy lamps.
Remove the courtesy lamp lens, then remove the screws.
Remove the two headliner front pin-type retainers.
Remove the two headliner rear pin-type retainers.
CAUTION: If the safety belt retractor is to be reused, do not allow the safety belt to be retracted all the way into the retractor. Doing so may cause the retractor to lock and not release the safety belt.
NOTE: Inspect the shoulder safety belt guide and cover for damage. If the shoulder safety belt guide or cover is damaged or cover does not remain closed, install a new shoulder safety belt guide.
Lift up on the cover and remove the front and rear seat nut and shoulder safety belt guides.
Remove the front and rear door scuff plates.
Position the B-pillar trim panels aside.
NOTE: The left front seat back must be fully reclined.
NOTE: Make sure not to damage the headliner when removing it from the vehicle.
Remove the headliner through the rear window opening.
To install, reverse the removal procedure.
Old Dec 5, 2011 | 09:32 AM
KellerMAC's Avatar
KellerMAC
Thanks Mueckster - it appears that it is more complicated than I originally thought.
Old Dec 5, 2011 | 09:54 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
When I removed mine I did not remove the rear window and was able to get it out the front door opening without creasing it. It's really not a big job just alot of screws to remove. Took me 30-45 mins tops to get mine out.
Old Dec 5, 2011 | 07:53 PM
F250_'s Avatar
F250_
There have been a number of folks who were not so lucky as you, though, Costa. Creasing seems to have been a very real issue for most who don't take out the back glass first.
Old Dec 5, 2011 | 08:04 PM
WA.Ranger's Avatar
WA.Ranger
Clay and I removed mine through the passenger side door. We removed the center console and the seats, then took it out. Not a bad job. You will have to slightly bend it near the edge, but it didn't crease it. YOU MUST USE EXTREME CAUTION!
Old Oct 9, 2015 | 06:05 AM
jetdoc's Avatar
jetdoc
Can you re use the rear window weatherstrip???
Old Oct 9, 2015 | 09:54 AM
F250_'s Avatar
F250_
It is my understanding that the rear weatherstrip CAN be re-used. Someone please correct me if I'm wrong.
Old Oct 9, 2015 | 10:06 AM
jetdoc's Avatar
jetdoc
That's what I was told this am as well. As long as the seal is still pliable and not weather cracked. New one is 68 bucks from Ford.
Old Oct 16, 2015 | 06:47 PM
jetdoc's Avatar
jetdoc
Went to go and reinstall back window today. Enlisted my teenage daughter, (hair and nails) to help. Wow, that didn't go as planned. Window sealant went everywhere. I mean EVERYWHERE! The seal popped out where we started. We used two gallons of lacquer thinner to clean up and I still have this black stuff on my hands. My girls a trooper though, aint complained a lick. Tomorrows another day.
Gof2274385
Aug 5, 2016 06:41 PM
kotro
1997 - 2003 F150
Aug 18, 2008 09:12 PM
rednekrebel28
1997 - 2003 F150
Jan 25, 2008 08:43 AM
lmrapp
Nov 1, 2007 02:02 PM
