General Automotive Discussion
Mopar Power loss problem
Old Mar 26, 2006 | 12:29 AM
bitesomthing's Avatar
bitesomthing
Ok i know its not a ford but need a little help,
I have a 1980 Motor home that has a dodge 440( i think ) in it. the problem i have is that when i press the gas pedal more then 3/4 of the way down i lose all power, i mean ALL POWER, it loses lights, Radio, and kills the motor after i lift up on pedal a little it usually starts running again.
I do not know how the gas pedal would even connect with electric power but something is going way wrong with it.
This problem started after i have put about 100 miles on it, I bought it used and have only had it on one trip, It did not act funny on the way to my trip, but did start just as i started to head home.
If i feather the gas peddle i can get up to speed such as 65-70 mph and not have a problem til i mesh down on peddle ( to pass someone or climb hill) then the power ( ELectric and gas) both die out then resume power if i lift up one peddle.
Any help is surely appreciated,
Thanks Chris
Old Mar 26, 2006 | 12:45 AM
76supercab2's Avatar
76supercab2
sounds to me like the throttle linkage has chafed a wire somewhere. I would try to inpsect the linkage under the dash and under hood. activate it and see if it touches any wires.
Old Mar 26, 2006 | 01:23 AM
Ford_Six's Avatar
Ford_Six
Maybe it has a bad motor mount and is pulling a wire taught as the engine torques over?
Old Mar 26, 2006 | 02:03 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the power with the engine off, if it fails then it is probably in the pedal linkage. If the power does not go off I would suspect engine motion.
Old Mar 26, 2006 | 09:46 PM
bitesomthing
Thanks to all for your help, It turned out that the LInkage was sliding back into a wire that had about 3/8 bare wire between the connector and the plastic wire cover.
Thanks again
Chris
MichiganLarry
May 26, 2016 10:00 PM
kodiak_f250
May 20, 2015 04:57 PM
90pioneer
6.4L Power Stroke Diesel
Apr 16, 2015 03:30 PM
radmacks
Apr 10, 2015 10:18 PM
shawndavis
Nov 15, 2003 09:50 PM
