Significant power loss after driving the truck hard. What could be wrong?
I have a 2008 6.4 F350, bone stock, with 91k miles.
Yesterday I drove the truck about 300 miles and on the way back home I was pushing it pretty hard, going 60-80mph through the mountains. Well I came up on a car in front of me and went to pass... BAM, no power at all, truck slowed to 50 and then 40 mph.
All gauges looked fine, no check engine light. Ironically it was at the dealership yesterday morning for an oil change. They also drained my water separator too.
I stop, shut truck off, and restart. Same problem, no power. With the peddle to the floor, RPMS at 2750, truck at 40mph, and losing speed. I was able to watch the RPMS go up when I punched the go peddle, but the speed did not increase.
I pull off to the side of the road, and check fluids. Everything looks fine. I sit there about 20 minutes, start truck back up. And it's back to normal. WTF.
It did this once before a couple months ago after I drove it hard. Next morning it was fine and has been, until last night.
Any idea what could be wrong?
I took it up to Oreily's auto parts and hooked up their scanner today. It said there was no codes stored ????
6.4LPowerloss
Ford has indicated so far code p040d, which is a EGT sensor. Can a bad EGT sensor cause vehicle to lose power or go in a limp mode?
Does computer tell them which EGT sensor is bad? They are also replacing the tube or part that the EGT sensor is plugged into. Not sure what that is called or why they replace that as well???
