1978 - 1996 Big Bronco
93 bronco acceleration vibration-HELP!!
Old Mar 20, 2006 | 01:07 PM
gemmBronco's Avatar
gemmBronco
Unhappy 93 bronco acceleration vibration-HELP!!
Hello. I have a 1993 Bronco with 108,000 miles. Recently, she started vi brating at around 30-40mph when under a load. It gets worse on hills and such. The vibration used to be erratic, but now is always present at the above speeds. I tried to wobble to driveshafts with my hands, but they seemed tight. Also, (I don't know if this is related or not) she will often die when put into reverse.
Any help with this problem is greatly appreciated. Thanks for your help!
Old Mar 20, 2006 | 03:08 PM
gemmBronco's Avatar
gemmBronco
Is there some reason why nobody has responded?
Old Mar 20, 2006 | 03:36 PM
Kemicalburns's Avatar
Kemicalburns
pull codes, fordfuelinjection.com will show you how. have you checked tranny fluid with rig running? tires might need rebalanced as well.
Old Mar 20, 2006 | 07:02 PM
broncobob's Avatar
broncobob
I'm going on the assumption that you have the E4OD transmission, if not then disregard. When the vibration starts, tap the brake pedal lightly. If the vibration stops for a short time then comes back, most likely is a slipping lockup clutch in the torque converter. Pulling the trouble codes should help confirm this, there are a couple that show up. When my 94 first started showing this symptom, I flushed the transmission fluid and the problem cleared up for a while then returned. Bad news is the only way I've heard to fix this is replacing the torque converter, which in my case means rebuilding/replacing the transmission since it has over 100k on it.
Old Mar 20, 2006 | 11:06 PM
greystreak92's Avatar
greystreak92
Codes first as Kem said. Its a LOT easier to diagnose and you are less apt to chase things that MIGHT be the problem.
Old Mar 21, 2006 | 09:38 AM
gemmBronco's Avatar
gemmBronco
Thanks for all the great response everyone . I guess I'll check the codes today.
Another note-I tried to spin the front driveshaft while I was under there and it spun for about 2 revolutions then wouldnt go anymore. The tranny was in park at the time. Don't know if this is normal or not. It was odd though, as the rear drivshaft wouldnt budge a mm from trying to spin.
I'll post what the codes read later today.
Old Mar 21, 2006 | 10:19 AM
gemmBronco's Avatar
gemmBronco
OK... WTF is the deal with Avatars!!! I tried for about 1/2 hour to save in every different .jpg, .gif, .pnd format and every time there was some problem!
(just venting)
Old Mar 21, 2006 | 11:42 AM
topfisherman's Avatar
topfisherman
The rear drive shaft will not spin unless the truck is in neutral with at least one tire off the ground. Do you have the stock automatic locking hubs on the front? If you do, that is why the front driveshaft rotated only two times, it takes them a bit to lock in.
Old Mar 21, 2006 | 04:33 PM
gemmBronco's Avatar
gemmBronco
OK- I pulled the codes out today. Man, that is really trying a persons patience in order to do so Anyway, I came up with: it's running rich, coil(s) are possibly bad, O2 sensor not functioning properly, and converter solenoid 3-4 is bad. Does any of this have anything to do with my vibration problem?? It seems like the best bet would be the converter solenoid, but how do I know for sure? I hope this doesnt mean a tranny rebuild. Any further adivce is much appreciated. THANKS
Old Mar 22, 2006 | 10:57 PM
BigOleChet's Avatar
BigOleChet
Mine had the infamous convertor shutter. I found another past thread where someone had bought a little red tube of "shutter stop" from O'reilly's and it had fixed the problem. I believe it is a friction modifier. I tried it and it totally took the shutter away (to my surprise and amazement). However, I didn't have the solenoid code. So, you may have more to deal with than I did. The O2 showing bad may be what is causing the rich condition. Oh, and if you are having a hard time counting codes, you can buy a code reader for about $35 (saw one yesterday at O'reilly's. It makes it alot easier. Good luck!
Old Mar 24, 2006 | 10:26 AM
gemmBronco's Avatar
gemmBronco
Thanks again for everyone who responded. I'm going to pull the driveshaft today and grease the joint under the rubber boot thingy. I'll post a response as to my success.
Old Mar 24, 2006 | 01:19 PM
gemmBronco's Avatar
gemmBronco
New update- I went under the car to remove driveshaft and discovered upon turning the bolts that the problem IS the double-cardon u joints. They were moving around and clanking when i only moved the driveshaft about 1/16th of a turn. Guess my original estimate was incorrect. I'm going to search this forum for advice in getting those darn bolts off w/o an air tool.
Old Mar 28, 2006 | 03:28 AM
81-87-93.ford's Avatar
81-87-93.ford
if that is not it read the thread
"tranny of fuel" that i started.. i had an issue with my torque converter.. a small tube of additive to the tranny fluid knocked out my vibration during acceleration up hill.
Old Mar 28, 2006 | 03:32 AM
81-87-93.ford
to help you find it.. the thread was last updated on 3-24 or here is a link to it. i dont know if the link will work correct though???
https://www.ford-trucks.com/forums/s...d.php?t=473615
roboduck75
Mar 22, 2017 10:35 AM
Jco06
2009 - 2014 F150
18
Jun 12, 2016 10:15 AM
chizzy matt
Aug 1, 2011 05:58 PM
Skagit
Apr 25, 2003 10:23 PM
mjwhillock
13
Jul 7, 2002 09:57 PM
