ac belt vibration 460 engine
Old Jul 30, 2011 | 08:31 AM
chizzy matt's Avatar
chizzy matt
Question ac belt vibration 460 engine
Does anyone have ac belt vibration issues on 460 engine.My truck is a 78 F150 with factory air and the belt vibrates when compressor is engaged. everything in the system is new except the condenser. I had a 79 Bronco in the early 90s with ac and a 351 but I dont remember if the belt vibrated and made noise back then.
Old Jul 30, 2011 | 10:11 AM
bamaf150's Avatar
bamaf150
Are you talking about a rumbling noise when the ac is on? If so, thats a common thing with the York compressors, nothing to worry about.
Old Jul 30, 2011 | 10:58 AM
chizzy matt
There is a rumbling noise and the belt vibrates a bit I have heard that on a 460 it is such a long belt run that it is normal. Truck did not have ac when I got it took the System out of a Junker and installed on mine which was a huge job. I copied the Ford system as close as possible if my vibration and noise is common to york compressors thats good to know!
Old Jul 30, 2011 | 11:18 AM
bamaf150's Avatar
bamaf150
I'm not sure if its the compressor or the belt's vibrating that causes the rumbling but there was a thread here concerning just that a few weeks ago and the general consensus was that it is very common and nothing to worry about. Both my '79s made the noise with the ac on.
Old Jul 30, 2011 | 12:29 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yorks are notorious for vibration (that's why I'm converting to a Sanden style on my project) add to that a long, unsupported belt run and that just magnifies the vibration and noise problem.
In your installation you should have two idler pulleys, one adjustable (basic p/n 8678) and one fixed (also basic p/n 8678). Be sure you have both of these.
Click on the .pdf link to view.
File Type: pdf
Old Jul 30, 2011 | 04:39 PM
bamaf150's Avatar
bamaf150
Hat is off to you on the ac installation, that must have been quite a job.
Old Aug 1, 2011 | 06:41 AM
chizzy matt
Installing factory ac in a truck that had none was a huge job so just imagine my dismay when you fire it up for the first time and it makes that noise. Thanks for your input guys.I do have the second fixed idler pulley to the left of the compressor I figured that one out when I saw a picture OF a 460 with air.
Old Aug 1, 2011 | 12:14 PM
Supercab's Avatar
Supercab
Those idler pulleys are notorious for having bad bearings that cause the vibration you describe. I had a '78 F150 SuperCab with a factory 460/c6 setup.
I know the old York compressors are kind of noisey but try replacing the idlers first-just be sure to get ones with steel bearings, I got some with plastic bearings some years back and they lasted about 4 months.......
Old Aug 1, 2011 | 01:55 PM
Don S.'s Avatar
Don S.
You'll know quick when the bearings fail. I had my upper die on my idler, Siezed and made all kinds of rukus under the hood. And burning belt rubber.
Old Aug 1, 2011 | 04:45 PM
chizzy matt
Mikeo peaked my interest in this sanden compressor . I imagine it is a rotory type. does anyone make a kit to bolt on a 460 without having to change all the pulleys evaporator ect?
Old Aug 1, 2011 | 05:16 PM
bamaf150's Avatar
bamaf150
Check ebay, there is a bracket that allows you to bolt a Sanden comp where your York went.
Old Aug 1, 2011 | 05:58 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Nostalgic Air makes the bracket that bolts to the original York mount then the Sanden bolts to that.
I haven't gotten that far but I believe the hoses will need to be changed.
www.nostalgicairparts.com
Future_LEO
Modular V10 (6.8l)
Sep 19, 2011 09:02 PM
chizzy matt
Jul 30, 2011 08:01 AM
04F250PSD
Aug 16, 2010 03:12 PM
Carny
Dec 18, 2009 10:37 PM
03eddie
Jun 23, 2006 11:38 PM
