Sponsored by: Real Truck
Vibration Help
Old Mar 22, 2017 | 09:48 AM
roboduck75's Avatar
roboduck75
Vibration Help
My 2003 Ford F250 V10 seems to have a vibration, sometimes at all speeds and sometimes at freeway speeds. I replaced front hub assemblies and ball joints and rear calipers last year. when braking i have a vibration in rear as well, which i think is from uneven rotor but can it be causing my vibration? also sometimes i can smell hot brakes from the rear.
Old Mar 22, 2017 | 10:22 AM
Copper.Farm's Avatar
Copper.Farm
It might be time to replace the brake hoses, inspect the caliper pins and flush the system with new brake fluid while you are there, SpeedBleeder on each caliper makes the job easy one person ordeal.
Old Mar 22, 2017 | 10:35 AM
99f350sd's Avatar
99f350sd
Yes if your brakes are dragging they will heat up and vibrate... Try driving and not applying brakes for awhile. pull over and see which brakes are hot.. That will get you in the right spot if one or two are tight.
1trik76
1997 - 2003 F150
Jul 14, 2009 08:55 AM
unenthused
1983 - 2012 Ranger & B-Series
Jul 5, 2005 05:41 PM
umtigers
May 27, 2005 04:06 PM
KPMYSONS
1997 - 2003 F150
Sep 10, 2004 06:14 PM
Kikwear
1978 - 1996 Big Bronco
Dec 9, 2003 10:05 PM
