Fords MAF Conversion kit question.
Old Mar 22, 2006 | 11:13 PM
76cougar74100's Avatar
76cougar74100
how well does a tfs stage 1 cam work in a aod truck? what type of stall?
Old Mar 22, 2006 | 11:37 PM
EgoMan's Avatar
EgoMan
What would the alternate fireing order be opposed to the 302HO/351...?
Old Mar 23, 2006 | 07:07 AM
EPNCSU2006's Avatar
EPNCSU2006
The regular 302 order: 15426378
Old Mar 23, 2006 | 03:44 PM
MustangGT221's Avatar
MustangGT221
Probably not very good. Why would you want a cam designed for a mustang in your truck?
Get a cam ment for your application.
Old Mar 23, 2006 | 08:32 PM
76cougar74100
the truck cams dont have the lunpy idle im looking for
Old Mar 24, 2006 | 12:36 AM
MustangGT221
Lumpy doesn't mean power...wth do u want a lumpy idle on a street driven truck for?
Old Mar 24, 2006 | 06:01 PM
76cougar74100
so when i race somone ill blow their doors off!
i rarly drive the truck and on weekends i want to have fun with it.
Old Mar 24, 2006 | 09:55 PM
MustangGT221
Run a cam that works...otherwise you're leaving power on the table because you care too much about what the idle sounds like.
There are FAR better cams than the E cam or TFS 1 for this application. It's not like it's going to idle that much more differently.
Old Mar 24, 2006 | 10:03 PM
EgoMan's Avatar
EgoMan
Well like i posted in your other post the Crane 443941 cam is going to give you exactly what your looking for, It gives a nice beefy idle with plenty of chop. The differance is it will produce the torque you need to get your truck moving where the mustang cam wont because it was ground with the wrong LCA for your application...your going to be more sluggish off the line with the E303. No doubt it will get with the program but 941 will get you off the line quicker and pull hard the whole way....Im banking 40-50 ft pounds of tourqe more with the 941.
Old Mar 26, 2006 | 12:37 PM
76cougar74100
what if i put in a 1800 stall?
Old Mar 26, 2006 | 01:12 PM
EgoMan's Avatar
EgoMan
Thats not really much of a stall... I ran 2200 or 2400 in my mustang with the stock 5.0 for a long time, I dont think you need one but it wouldnt hurt.
69-390f100
Sep 22, 2005 07:30 PM
CaseyJones
1978 - 1996 Big Bronco
Dec 22, 2004 04:57 PM
sandman3510
Nov 29, 2004 11:22 AM
AeroPA
1983 - 2012 Ranger & B-Series
Oct 7, 2004 09:56 PM
stroker15
Jan 5, 2004 11:16 AM
