what rim for a 38 tall tire?
i have a 77 f-250 crewcab 4x4 that im going to put 38 inch tires on 16.5 rims what rims do i need what offset and how wide do they have to be or will the stock wheels work? the tires i belive are 38x15x16.5 super swamper trl radial. and what are the stock size of a 16.5 rim (the off set and back spacing and width)?
is this truck going to be a pavement pounder, or a mainly offroad truck? if its for the road, get a wider rim, as it will make the tires wear better, if you plan on mainly being offroad, get a skinnier rim, it will help hold the tire on the rim, but if you run a skinny rim on the road alot it will wear the middle of the tire more.
16.5s smaller beads
well i got the tires cheap and my truck has 16.5 stock wheels and i was thinking that could i use my stock rims and if i get some extra cash i was going to buy new rims but thats a ways down the road. and searching the net i found out that for the tsl radial 38x15x16.5 the Tread Width is 11.50 in and the Recommended Rim Width 9.75 in. but will the stock rim width work
Originally Posted by fordraceboy
... i run 38.5x15 boggers on 16x8 wheels and haven't lost a bead yet- and hae been down to as low as 8 pounds in the tires...
theguy_88
03-19-2006 09:47 AM
Doorgunner808
1978 - 1996 Big Bronco
10-13-2004 11:49 PM
