Intercooler on a '97
Old Mar 16, 2006 | 11:14 PM
CowboyUp1387's Avatar
CowboyUp1387
Anyone here done this or seen it? i don't wanna buy a banks kit for $1700 just for an intercooler. Are there any out there that would go in without too much modification? I'm game for doing customizing, but don't have too much money to put into this. Any help or info is apprieciated.
Old Mar 16, 2006 | 11:16 PM
1997F-350's Avatar
1997F-350
find you a cheap ic on ebay either from 6.slow or 7.3 and get a gts motorsports pipe kit. many have done this. its gonna be my next mod..........
or wait ...i think stacks will be.
Old Mar 16, 2006 | 11:21 PM
ltfox's Avatar
ltfox
I agree! I got a 6.0 intercooler off ebay for about 60 bucks(good deal!)
And am waiting on my kit from GTS to get it installed! Total is about 700 bucks! Beats the hell out of the $1400-1500 for the banks kit!
Old Mar 16, 2006 | 11:59 PM
ForemanES's Avatar
ForemanES
Hey just food for thought. How can banks get 120hp more than stock, out of stock injectors? It is just a chip, intake, turbo housing, exhaust and intercooler. Also is it worth it to buy one of banks intercoolers for less pressure loss compared to a stock SD 7.3, or 6.0 ic? Some say like 2-4 psi loss from an ic. Compare $1400 for banks to ~$800 for a gts kit and used ic. Is $600 worth 2-4 psi more boost? Just thinking
Old Mar 17, 2006 | 12:12 AM
1997F-350's Avatar
1997F-350
if you dont tow big and have bigger fuel i wouldnt waste your time.
that extra 120 was done on a 97 cali truck. fwiw
Old Mar 17, 2006 | 12:57 AM
ForemanES's Avatar
ForemanES
They have split shot injectors, right? Anyways cowboyup if you are looking for performance you can spend that $1400 for the banks intercooler and buy...
1) gauges about $300
2) exhaust $400
3) intake (tymar or napa 6637 filter) $100
4) chip (dp tuning flip chip) $400
All that for $1200 give or take. You didnt tell us much about your truck but just adding an intercooler wont help much performance wise.
Old Mar 18, 2006 | 03:28 AM
westtntrucker's Avatar
westtntrucker
I have 5" straight stacks on my '96. Looks great, sounds excellant, but will lower your fuel milage!!!!!!
The reason i say it will lower the fuel milage is you will always be wanting to hear the rap at full throttle! hehe!!!!! Definitly will turn heads!
Old Mar 18, 2006 | 08:09 AM
barebackjake's Avatar
barebackjake
an intercooler will increase performance since your getting a denser colder air charge. it dosnt make a huge differnce and the other supporting mods need to be in there like a 1.0ar exaust housing to help it spool faster. if you tow alot the ic is a big gain on the large hills, you will be able to run the hills harder and faster since it keeps the egt's lower. in my case i saw a increase in fuel mileage by 1-2mpg i credit the cooler air getting into the motor from this one.
i have had the aluminum 7.3 intercooler in the truck with some 130cc injectors and the gts pipe kit and it worked great. the 7.3 ic is good to about 300rwhp mark im running a differnt injector now and needed more intercooler so i have the hypermax taper core in the truck now.
its about a 8-10 hr install start to finish.
Old Mar 20, 2006 | 06:38 PM
Pest007's Avatar
Pest007
info
I Have a 96 PSD with that all the Banks goodies, except the intercooler, I do want one, but don't like the price, anyways I was told that my chip needs to be reflashed for more fuel output if I put a charge air cooler (intercooler) on, is this true, will it hurt anything with what I have, just wondering. And does anyone know what the difference between the 6.0 intercooler and the 7.3, if any difference??
1996 F250 4x4 PSD E4OD, Banks Stringer Plus kit - TransComand
Old Mar 20, 2006 | 08:42 PM
barebackjake
i would just go with the SD ic with the GTS pipes then. does the banks kit have a 1.0ar exaust housing? the way most of the aftermarket programming it its already close to the fueling limits of the injectors i wouldnt worry a ton about getting the chip burned yet. i would get the ic in and see how it runs then you can go from there.
Old Mar 21, 2006 | 03:46 AM
RubberDuck's Avatar
RubberDuck
Not to hyjack the thread, but Westtntrucker, you don't see a KW crossing a creek like that everyday. I'm assuming that's your truck? Cool picture.
ginomachino
6.4L Power Stroke Diesel
Oct 20, 2016 08:36 AM
Twitchyleprechaun
Apr 1, 2016 07:45 AM
jimlj
Jan 23, 2007 07:08 AM
bigsub
May 22, 2006 08:57 PM
jokerforever
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
37
Jun 26, 2005 06:42 PM
