fuel pressure test guage problems??
Old Mar 20, 2006 | 01:36 PM
JR270's Avatar
JR270
Question fuel pressure test guage problems??
I was wanting to do the fuel pressure reg. mod on my '97 F-250. Thought that I would take a pressure check before and after to see if I had any improvement or how much improvement I got. Went to check the pressure at the sch. valve, and my test guage just bounced constantly when the truck was running (idle), from about 40-60 psi on the guauge. Thought that maybe I had guauge problems as it had not been used in a long time, so I borrowed a friends guage (identical guauge as mine), and it done the same thing, worse if the the rpm's on the truck is increased. Any suggestions?? Do I have a problem that I am unaware of or just checking the fuel pressure wrong? Does the deisel take a special guage? My guage said not to use on deisel engines but I thought since it maxed out at 100 psi and I should be running below that amount that my gauge should be fine. The truck runs great, starts easy, idles good. Thanks!!
Old Mar 20, 2006 | 02:08 PM
barebackjake's Avatar
barebackjake
thats about normal since its a mechanical cam actuated pump its gonna bounce so i take the average of what your getting.
i used to use a tire pressure gauge when i still had the oem fuel system on it. sounds like the one your using is fine.
Old Mar 20, 2006 | 05:50 PM
tjbeggs's Avatar
tjbeggs
yep normal. the reason your gauge said not to use it on a diesel is they didn't want you to use it on engine that use an injection pump which have fuel pressure in the 1000's of psi range. but our injectors do all that work so they are just provided "low" pressure fuel
Old Mar 20, 2006 | 07:49 PM
MikeFromShiloh's Avatar
MikeFromShiloh
you need a liquid filled gage, they are built not to jump around with the pressure jumps caused by the mech fuel pump.
Old Mar 21, 2006 | 08:21 AM
JR270's Avatar
JR270
Smile
Thanks for the info and advice!! I will take an average of what I am getting and then proceed with my fpr shim.
kneddor
2004 - 2008 F150
Sep 5, 2024 05:01 PM
Diesel Submariner
39
Aug 7, 2015 01:11 PM
mstiles19
Aug 1, 2012 04:01 PM
garsm
Dec 14, 2011 10:11 PM
Sarge261
Sep 15, 2011 07:10 AM
