It helps a little. But you really want to put a switch in the circuit to be able to turn it on and off at will. It makes the truck idle rough.
Here's a diagram that I made of the one that I installed. I've moved on since then and use a Diablo Predator. If I stack it with the Predator the EGT's go through the roof.
Wow Kwik thanks,
So if what I'm reading is correct, if I go with a Diablo then I don't really need to do the 10K mod.. Right ??
That is true, but if you want to best spend your money give it to Jody Tipton. He's the king of the hill when it comes to enhancing the engine tune. www.dp-tuner.com
