352 bolt torque questions.
Old Mar 8, 2006 | 12:33 PM
66beater's Avatar
66beater
I'm putting in a T98 out of something unknown and big. its a 1-3/8s input spline, so the clutch and pressure plate are diffrent thanwhat I had before. its still an 11 inch, and the bolt holes line up, but its 20 pounds heavier and a diffrent shape.
Anyone have a guess as to what the pressure plate bolts should be torqued to?
And what about locktight? I have been told absolutly never use it on a pressureplate, and I've been told I'd be a fool not to. So is there a reason not to?
Old Mar 8, 2006 | 02:21 PM
Putt's Avatar
Putt
Are they 5/16" or 3/8" bolts?? The 5/16" bolts are torqued to 15-20 ft lbs, use good lockwashers. The 3/8" bolts are at 25-30 ft lbs. I have used the blue medium strength Loctite with no issues.
BTW the bellhousing bolts are torqued to 45-50 ft lbs.
bluegoose95401
Aug 28, 2014 01:03 PM
hound dog
1978 - 1996 Big Bronco
Jul 14, 2011 09:25 PM
tude
Nov 1, 2005 05:01 AM
magna19
Mar 15, 2005 04:35 AM
No_BS
Mar 9, 2005 11:50 AM
