radiator support
Old Nov 1, 2005 | 12:21 AM
tude's Avatar
tude
radiator support
Ok i have a 74 f100 and the radiator suport is rusted out majorly i was given a 78 3/4 ton
what all do i have to change i know the grill is diffrent and the headlights are square on the 78s so will all my old parts bolt on perfectly
im not as concerned a bout a grill but i WILL need the lights its only a $50 truck
Old Nov 1, 2005 | 03:03 AM
Pre'80's Avatar
Pre'80
The only difference between the core supports is some have the narrow opening, and some have the wider opening. A narrow opening can be made into a wide opening, but the wide opening won't work where a narrow opening one was without adding something to the right side to hold the radiator. Otherwise, the year, or what size truck it came out of doesn't matter. As long as it's for a '73-79. Now, the radiators were different in '73 and 74 on some trucks, but the radiator, as a whole, will bolt onto the other core support. Some radiators on the older ones....not sure what to call them...had stand offs??? that the radiator bolted to. The common way a radiator mounted was it bolted directly to the core support, these older radiators had the mounting flanges on the engine side, and used the "stand offs" to mount the radiator. If you have a radiator like that, make sure you transfer the "stand off's" too.
Old Nov 1, 2005 | 05:01 AM
old timer 4x4's Avatar
old timer 4x4
you might have to drill one hole on top inside . as the 78 rad support does not have it for the square headlights, but no big deal.
caninelver
Feb 15, 2010 06:54 PM
z1121jack
Mar 7, 2008 04:47 PM
cujo8
Nov 24, 2007 02:47 PM
78ford514
Dec 13, 2005 10:09 PM
oem78
Dec 9, 2004 12:08 AM
