Clutch set
Old Aug 28, 2014 | 01:37 AM
bluegoose95401's Avatar
bluegoose95401
Clutch set
So I finally got to the point of the build on my 390 I'm doing were i can install the clutch kit on my 390 I went to put it in and none of the pressure plate bolts line up ...... What are the chances that summit put the wrong pressure plate in my box . It's a hays 90-200 super truck . But it looks nothing like the pics On the internet do .the pics look to have A few diffrent mounting locations. I called to check aplication be for I bought it and they said this is correct one I also looked on the hays page and called then to confirm evry one said that the 90-200 was the right one the numbers on The box say the same number also .... On stumped any ideas
Old Aug 28, 2014 | 07:19 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Is the replacement pressure plate the same style as the original? What about diameter?
There are three different styles of pressure plates, Long, Borg & Beck and the diaphragm. They all use different bolt patterns.
The Long style has three skinny fingers that the throwout bearing pushes against. The Borg & Beck is similar except that the fingers are wider, and the diaphragm is completely different with a series of flat spring fingers.
As I recall, the FE uses the Long style.
The first picture is a Long, then the B&B and last, the diaphram style
Old Aug 28, 2014 | 12:10 PM
bluegoose95401
The hays one that I got is a diaphram style does this mean that I will need a new fly wheel why is it made for a 390 if if dosnt fit the stock stuff
Old Aug 28, 2014 | 12:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0
what pressure plate did your truck originally have?
Old Aug 28, 2014 | 12:53 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I looked in the Ford parts catalog and it shows only one pressure plate for the 390 from '73-'76, P/N D4TZ-7563-A.
I tried to find a picture of the part number and only came up with one and that was a Long style plate, I'm not sure though that it was a picture of the actual part or a generic picture.
The catalog shows that the 390 used an 11½" clutch disc and the 360 used a different plate because it used an 11" disc.
Old Aug 28, 2014 | 01:03 PM
bluegoose95401
This is an 11 " disc so it must be for a 360 then
Pappawheely
May 30, 2018 08:04 AM
brepei
Sep 30, 2015 12:35 PM
White97
Aug 20, 2008 06:31 AM
vernsfords
Aug 7, 2005 06:24 PM
pottymouth2
Jun 8, 2004 11:38 PM
