8.8 to 9" conversion.
Old Mar 8, 2005 | 02:45 PM
No_BS's Avatar
No_BS
i've found a few 9" rears at a local junk yard that I can get for under $50 and I was wondering what would bolt up, and what would have to be changed, expecially with the brakes, are any of the parts interchangable, and will the diffrent flange setup bolt right to my driveshaft or will I need something diffrent? Also, did the 9" come with 3.55 gears? Thanks.
Old Mar 8, 2005 | 03:23 PM
andym's Avatar
andym
Brakes are different. Watch the lug pattern, mustang 9" axles came with 5 x 5" lug patterns.
Depending on what you're going to bolt into, it may not work at all. 92 & up trucks use a VSS. No 9" came with a VSS, and your speedo and electronic tranny depend on that signal. '91 & earlier and you'll be ok, but you'll still lose the rear ABS.
9" axles came with 3.50 gears, not 3.55 gears. If you have 3.55 now, then you have a 3.54 front, and that' VERY close to being incompatible with a 3.50. I would definately not run it on anything remotely close to a hard surface. Not even a dirt road.
Springs and shocks should bolt up, not sure about the pinion flange. Try searching the diff, trans, and axle forum. This comes up a lot there.
Old Mar 8, 2005 | 06:10 PM
f_ford_custom's Avatar
f_ford_custom
Why 9? The 8.8s are just as strong, and less friction. Best of all, you already have em.
Old Mar 8, 2005 | 08:28 PM
Mr. Finch's Avatar
Mr. Finch
Not to steel the forum or anything, but what is the advantage of having a 9" over an 8.8", or an 8.8" over a 9".
Old Mar 9, 2005 | 02:17 AM
aurgathor's Avatar
aurgathor
9" axles are a bit beefier and have an extra bearing, and that helps off-road.
Old Mar 9, 2005 | 07:22 AM
RTM's Avatar
RTM
The broncos and f150 trucks came with a 9 inch rear until around 85 or 86 so the 3.50 ratio is fine. Your not suppose to use 4X4 on any hard surface such as pavement, only slippery conditions.
The 8.8 in stock form is not as strong as a 9 inch. Why, the 9 inch an extra pinion bearing which provides a much better support to the pinion and the carrier itself has extra spider gears, again better support. Plus the 9 inch can break an axle and not have it fall out of the housing.
Can an 8.8 be built up, yes but in stock form you can not beat a 9 inch. IMO it is far stronger than an 8.8.
Almost 99% of the 4X4 trucks will have the 3.50 ratio. I have found the same gear ratio in vans and 2 wheel drive trucks but are a little harder to find. be careful because I have pulled 28 spline set ups from vans before. For a truck try to stay with the 31 spline set up.
Old Mar 9, 2005 | 09:26 AM
82F100SWB's Avatar
82F100SWB
The 4x4 trucks with 3.50 gears came with 3.50 gears in the front also, not 3.54's. I have a couple examples of each in my TTB parts pile.
Old Mar 9, 2005 | 11:50 AM
RTM's Avatar
RTM
Aren't the TTB front 44 gears the same as a staright 44 axle? I seem to recall the gears could be swapped between the two with no troubles. I have yet to see a fron axle ration be the same as the rear? I am no expert but I would like to make sure I know what I am talking about so any info you have would be great.
ah1988
Oct 22, 2010 10:19 AM
jstutz101
Aug 4, 2008 09:17 AM
Krochus
Ford vs The Competition
Oct 11, 2006 03:11 PM
66beater
Mar 8, 2006 02:21 PM
GWB
Mar 22, 2000 01:45 AM
