Well when You change a tire and go to a bigger size the speed or the amount of turns the driveshaft spins to turn a bigger wheel is different, so when you go to a taller ratio you can make the motor rpms match what they used to be with the stock tires giving you more power and and better mileage. The rule of thumb i have always heard is you get most of it back minus about 10% due to the new added wheel weight and aerodynamic drag. Unless of course your truck is gigantic with 44's
I agree but those 235/85 tires are tall (31.7 in). How much rpm gain do you think moving up to a 33.2 in. tall tire?
I believe there may be some confusion about tire sizes.
LT235/85-16
LT = light truck
235 = width of the tire in millimeters, a 255 is wider than a 235 by 20 millimeters
85 = ratio of height to width (85% of width or 75% of width, an 85 is a taller tire than a 75)
16 = diamter of wheel in inches
A taller tire will lower your rpm which should help improve your fuel mileage unless you are running a wider tire too which may cause more drag. A shorter tire will raise your rpm at the same speed resulting in lower fuel mileage.
LT235/85-16
LT = light truck
Keep asking silly questions and you might learn something arouynd here.
31.7in tall is the hieght of tire i am running right now. BFG commercial TA 235/85/16. Im looking for taller RPM lowering tires.
