Looking for a programmer
Old Feb 28, 2006 | 05:34 PM
jimkidd's Avatar
jimkidd
Arrow Looking for a programmer
Does anyone know of a programmer thet I can use to set my speedo with? I put bigger tires on my 1 ton.
jimbo
Old Feb 28, 2006 | 06:00 PM
ForemanES's Avatar
ForemanES
I know that my edge evolution wont change the speedometer reading, just removes speed limiter. I dont think superchips does either. The predator does but it doesnt work on the obs psd. Maybe hypertech?
Old Feb 28, 2006 | 06:54 PM
walt1968's Avatar
walt1968
jimbo
Do this: (I just got done doing it to mine, same year as yours and works like a charm)
Recalibrate Your Speedometer After Changing Tire Size
There is no tire size/code chart because tire size vs. actual tire dimensions are different between manufacturers. Even between the same tire size and same maker there will be a difference in actual size between the different tread designs.
The Ford calibration equation is:
20186 / tire height in inches = some number, then: some number /.6666 = program code
Example:
Start with 20186, divide by actual tire size in inches. Divide again by .6666
You want to use a rolling measurement to get your actual tire height (If you try to measure the tire in the driveway, use conversion charts, or anything else you will end up with an inaccurate reading again). Use your rear tire since the sensor is located there. Mark the ground and your tire and roll forward 3 times marking the ground each time. (I ran over a spot of oil at a local gas station and measured between my tread mark prints), then divide that number by three to get the average length of one revolution (this will protect yourself against a bad reading using just one revolution). You can then divide the length of one revolution by 3.14 to get actual tire height. Be careful in your measurements, a small amount will change the code. EX: 31.69" tire height is code 956, and 31.21" tire height is code 970.
Now, to program it into your truck:
Warning: You can only change the calibration 6 times without replacing the module.
To set the calibration, ground the single wire connector under the glove box it says PSOM (Programable Speedometer Opdometer Module). ”Yes there is only one and it has a spade type plug on the end". I used a wire with clips on both ends to ground the plug to a screw under the dash or try a test light and use the clip end to the PSOM and the other jam in a dooe hinge. Now look at your speedometer on the face of your dash while sitting in the drivers seat and there should be a "reset" button and a "select" button. While holding the reset button in on the trip meter, turn the ignition to 'on' while the wire is still grounded. Let go of the reset button. The speedometer display will sweep once and will show a code of some kind then push in again the "reset" button and the existing code will be displayed with RECAL?, mine said 976 RECAL? Now you enter your new code you came up with by dividing the rolling measurement by PI or 3.14 by pushing the "select" button until it gets to the new calibration code number. You may have to push “select” a whole bunch of times until you get to your code. If you turn off the key at this point the original code will not be changed or any of the 6 lives will not be used. To store your new code press “Reset”. Turn off the key. Unplug the ground wire. To check the new calibration, use the mile markers on the interstate. Run an indicated 60 mph and it should take exactly 60 seconds to go 1 mile.
Old Feb 28, 2006 | 07:13 PM
jimkidd's Avatar
jimkidd
Would rear end gear ratios have any bearing on the constants in the above formula?
jimbo
Old Feb 28, 2006 | 07:31 PM
walt1968's Avatar
walt1968
jimbo
I think it would if it is different than what was configured in the truck to begin with. Not sure though.
Old Feb 28, 2006 | 09:59 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
That's the calibration I was telling you about on the phone earlier.....I didn't think it would be too hard to find.
Old Feb 28, 2006 | 10:18 PM
jimkidd's Avatar
jimkidd
It's easier to ask than to search! Do you know about the rear end ratios?
jimbo
Old Feb 28, 2006 | 10:52 PM
fishmanndotcom's Avatar
fishmanndotcom
jimbo
here..... bookmark this and read it like its sacred! careful though, you might learn something. sometimes its better to give the website than to copy and paste
http://pages.prodigy.net/stevebaz/_i...az/index3.html
-cutts-
Old Mar 1, 2006 | 05:56 AM
walt1968's Avatar
walt1968
-cutts-
Sorry about the copy and paste thing as I had it on my computer and just got in from doing it. It won't happen again I promise!!
Old Mar 1, 2006 | 08:04 AM
fishmanndotcom
no no, nothing to be sorry about.... i just thought he would benefit from getting the whole site! thats all
-cutts-
Old Mar 1, 2006 | 08:30 AM
walt1968's Avatar
walt1968
-cutts-
I agree though, that page is worth everything to everyone!!!
Old Mar 1, 2006 | 08:52 AM
jimkidd's Avatar
jimkidd
Thanks to everyone!
jimbo
Old Mar 1, 2006 | 08:56 AM
jimkidd's Avatar
jimkidd
Arrow
No one has satisfied my question about the rear end gear ratios.
jimbo
Old Mar 1, 2006 | 11:50 AM
1997F-350's Avatar
1997F-350
jimbo
hey jim in all the talks of anyone ever doing this to there truck i have not heard it mentioned once. i think you will be fine.
Old Mar 1, 2006 | 12:09 PM
walt1968's Avatar
walt1968
jimbo
I think I get what your asking now.......This is a Ford equation that works on all the trucks as long as you have the same ratio that came with the truck or is matched with the computer. Ratio has nothing to do with the equation....as it is the same for all the Fords.
