KOER code 4?????
Old Aug 22, 2024 | 10:23 PM
MitchellR95's Avatar
MitchellR95
4wd Low
Lead driver - I was able to successfully upload it to my YouTube. Please take a few minutes of your time to take a glance at it and give me your thoughts.
Old Aug 23, 2024 | 12:03 PM
Junktownbill99's Avatar
Junktownbill99
You counted the separator code, that last code is 34.
It goes: quick flash - KOEO codes - repeat once - separator code - CM codes - repeat once
If I remember correctly, the quick flash is all the codes flashed at like 100x speed.
Old Aug 23, 2024 | 12:51 PM
MitchellR95
4wd Low
Laughing gas - Okay, I'm going to re watch it when I get home. I understand the koeo codes and then they repeat once. After that I'm generally confused what I'm doing wrong haha..
Old Aug 23, 2024 | 12:55 PM
Junktownbill99
Originally Posted by MitchellR95
After that I'm royal confused what I'm doing wrong haha..
​​​​​​Long pause, 1 flash (code 10) long pause
Your first CM code is 22, not 12, that "1" is the separator code.
Old Aug 23, 2024 | 01:00 PM
MitchellR95
4wd Low
Ohhh... so I just need to transfer everything 1 digit over to get the correct codes. 22, 41, 31, 32, 34 then it repeats twice.. okay now that makes sense! Thank you!
How've i have code 10 as an issue then too right?
Old Aug 23, 2024 | 01:07 PM
MitchellR95
4wd Low
So I just re watched the video and that makes much better sense. I guess my question is that single flash (code 10) it always pops up as a single flash with a pause before and after it right?
Old Aug 23, 2024 | 01:10 PM
Junktownbill99
Yes, it is separating the KOEO and CM codes.
Old Aug 23, 2024 | 01:41 PM
MitchellR95
4wd Low
Laughing gas - sense you've been assisting me so far. I looked to see how exactly you do a cm read. I found this post from someone else. Guessing i did it wrong?. I jumped the self test out to the self test in. If you have a minute can you tell me the proper way to jump to test both koeo & cm codes and how its done. I read elsewhere that one set the motor has to be cold & the next hot. I just did koeo on a cold motor with the jump i stated above to get the codes in the video. Thanks in advance!
Old Aug 23, 2024 | 06:18 PM
Junktownbill99
KOEO codes are hard faults that the computer can "see" (a voltage out of range, a solenoid not responding, etc)
CM codes are ones that the PCM picks up as they show up, as you can't check codes while driving.
When you turn the key, it runs KOEO - (separator code) - CM
It's best to run it in a warm motor, but it works either way.
Old Aug 24, 2024 | 06:42 AM
My4Fordtrucks's Avatar
My4Fordtrucks
4wd High- As was mentioned, code 10 is not an actual code but is a separator between active codes and codes that are stored in the memory.
This is why myself and a most others use a code reader like the Innova 3145. It displays the actual codes so you don’t have to try to count the flashes.
Old Aug 25, 2024 | 02:05 PM
EPNCSU2006's Avatar
EPNCSU2006
Self test-in jumpers to Sig-Rtn or ground to trigger the computer to enter the test. Self test-out is used to view the codes - it is tied to the check engine light. I think you have the digits sorted now.
rfranzke
30
May 27, 2023 07:10 AM
95f150v8
Apr 11, 2008 07:54 PM
nobodyspecial
18
Feb 3, 2007 10:05 AM
kevin-11
May 4, 2005 01:08 PM
mattd860
1983 - 2012 Ranger & B-Series
15
Sep 12, 2004 09:55 PM
