code 538 help please
Old Jul 18, 2005 | 06:58 PM
95f150v8's Avatar
95f150v8
Hello All,
I am getting a trouble code that I do not know what to do to fix it.
Please help. The code is:
538 insufficient rpm change during KOER dynamic response test.
What does that mean and how do I fix it?
Thanks
Old Jul 18, 2005 | 08:50 PM
Rotor's Avatar
Rotor
Wow, an easy one! Sounds like you read that right out of Chilton's. My copy is from "97" so pages may be different, but under "Driveability and Emissions Controls" page 4-48 I quote " Certain Ford vehicles will display a Dynamic Response code 6-20 seconds after the engine ID code. This will appear as one pulse on a meter or as a 10 on the STAR tester. When this code appears, briefly take the engine to wide open throttle. (WOT) This allows the system to test the throttle position, (TPS) MAF and MAP sensors.
If you ran a KOER test and got a 538 all it means is you did not hit the gas at the right time. Unless you got other codes your engine is fine as far as the puter is concerned. Hope this helps, Karl.......
Old Jul 18, 2005 | 09:25 PM
95f150v8's Avatar
95f150v8
thanks karl
Old Apr 11, 2008 | 07:54 PM
geraldo14's Avatar
geraldo14
code 538
I'm glad you asked this question and I'm glad Karl answered it, I too recieved the same error code even after replacing the TPS which was a pain in the A*s. When exactly are we supposed to depress the throttle? I have an INNOVA OBD2/OBD1 code reader.
Thanks....
Jerry
bruggeri
17
Apr 2, 2014 01:04 PM
Bankrupter
Aug 28, 2011 12:24 AM
larry1211
Electrical Systems/Wiring
Oct 16, 2007 06:31 AM
Leadsled Coupe
May 6, 2004 05:20 AM
