32 gallons in my 29 gal. tank!
When filling my '04 6.0 F250 diesel last night, the attendant took his time, kept
stopping after pumping just a little fuel, tapped the nozzle a bunch, and got
32 gallons in my tank! I've never gotten over 27.something before. He said if
you go easy and let the foam die down, you find out what it really will hold.
Drove over 50 miles today, and needle hasn't moved off of full yet.
Maybe this isn't news to some, but I was amazed----re-checked my owner's
manual, and it definitely says 29 gallon capacity....
All it is, is you drop the tank and take the sending unit out of it and reach up inside with a set of pcv pipe cutters and cut the vent tube off (the smaller one) in the tank and then take the cut piece out of the tank and put it all back together. What this does is let the foam out threw the vent hole and not have 6 inches of foam on top of the fuel while filling. I did this to mine after my second tank full and wouldn't have it any other way either.
Found this on the top of this forum's page. It is in the tech folder. Click below and you should get the info you need to do the harpoon.
https://www.ford-trucks.com/forums/a...poon-The-Tank?
Good Luck
Good Luck
