32 gallons in my 29 gal. tank!
Originally Posted by eharman
I have driven over 160 miles on a trip before the needle fell below the full mark.
It is nice to have the added capacity. And it takes sooooo long to top off without the harpoon. Some day, oh some day, I'll break down and do the harpoon thing.
Originally Posted by Kiteman44
When filling my '04 6.0 F250 diesel last night, the attendant took his time,...
Oh ya...I fill mine as far as I can before a long towing trip.
Originally Posted by Btravelen
OK, so no drawbacks. What is the purpose of the way the tank was designed? Is there potential for venting fuel overboard under certain circumstances (hot day)?
#28
The gasoline vehicles need the air space at the top of the tank for the fuel vapor recovery system to function correctly; all part of emissions requirements.
As far as filling the diesel tank...
As you put fuel in the tank the fuel will displace air; the air will go out the vent tube (that sticks down a few inches from the top of the tank) which has a vent hose back toward the top of the filler neck. Once the fuel level has risen enough to cover the vent tube there is no easy way for the air to be displaced; fuel backs up the filler neck and hopefully the pump cuts off. You can then slowly fill the tank to the brim as the air being displaced goes back up the filler tube.
Cutting off the vent tube (harpoon mod) allows more fuel in the tank because the air can freely escape via the vent tube to a higher fuel level.
My only regret is that I did not do this mod earlier.
Bob
Bob
#29
Bob
Bob
As for the leaks, when I first harpooned, I didn't get the sending unit ring on straight, and I had some drips. I re-did the ring and haven't lost a drop since.
#30
There is not separate tanks for gas vs diesel engine trucks and the EAP requires, I believe, a 10% expansion area for gassers after filling up. So a 28 gallon tank would be expected to hold about 31 gallons at a minimum. If you want to have some sticked shock fill a 44 gallon X to the neck!!!
RoyC
RoyC
ford390gashog
02-07-2006 01:16 PM
