32 gallons in my 29 gal. tank!
Old 02-23-2006, 06:50 PM
Kiteman44's Avatar
Kiteman44
Kiteman44 is offline
Exclamation 32 gallons in my 29 gal. tank!
When filling my '04 6.0 F250 diesel last night, the attendant took his time, kept
stopping after pumping just a little fuel, tapped the nozzle a bunch, and got
32 gallons in my tank! I've never gotten over 27.something before. He said if
you go easy and let the foam die down, you find out what it really will hold.
Drove over 50 miles today, and needle hasn't moved off of full yet.
Maybe this isn't news to some, but I was amazed----re-checked my owner's
manual, and it definitely says 29 gallon capacity....
Old 02-23-2006, 06:52 PM
HeavyAssault's Avatar
HeavyAssault
HeavyAssault is online now
I top mine off till I see fuel at the cap. I drive over 100 miles then the needle passes the F.
Old 02-23-2006, 06:58 PM
general082's Avatar
general082
general082 is offline
Long Filler tube?
The 6.0 Grin
Old 02-23-2006, 07:00 PM
MobeyDick's Avatar
MobeyDick
MobeyDick is offline
I put 40.315 in mine today! I have put 42.8 in the past!!
Old 02-23-2006, 08:26 PM
refuse2's Avatar
refuse2
refuse2 is offline
I get right at 141 miles before mine leaves full and love every minute of it, just wish it did this through the hole gauge drop process, but I can wish.
Old 02-23-2006, 08:38 PM
LVEILLON's Avatar
LVEILLON
LVEILLON is offline
I noticed a huge amount of Foam that is produced today while filling up a 6 gallon jug for a generator. I had to let it settle for at least 15 seconds so it wouldn't foam out of the neck. I'll have to try that next time I fill up my truck.
Old 02-23-2006, 09:41 PM
HeavyAssault
There is the HARPOON mod that cuts the vent tube that goes from inside the tank to the filler neck very short. This vent line allows the foam to back up the vent into the filler neck and making the refuel time extremely slow to the top.
Old 02-23-2006, 10:07 PM
refuse2's Avatar
refuse2
refuse2 is offline
I've done the harpoon mod and when mine clicks off I can just get .8 gallons into it before it touches the cap so it saved me a bunch of time at the pump freezing my butt off outside
Old 02-24-2006, 04:25 PM
jimmy-six's Avatar
jimmy-six
jimmy-six is offline
Heavy Assault & refuse2...Where do you find out about this harpoon mod...I've done a search and can't come up with anything...Thanks
Old 02-24-2006, 04:41 PM
refuse2's Avatar
refuse2
refuse2 is offline
All it is, is you drop the tank and take the sending unit out of it and reach up inside with a set of pcv pipe cutters and cut the vent tube off (the smaller one) in the tank and then take the cut piece out of the tank and put it all back together. What this does is let the foam out threw the vent hole and not have 6 inches of foam on top of the fuel while filling. I did this to mine after my second tank full and wouldn't have it any other way either.
Old 02-24-2006, 04:52 PM
olfordsnstone's Avatar
olfordsnstone
olfordsnstone is offline
Found this on the top of this forum's page. It is in the tech folder. Click below and you should get the info you need to do the harpoon.
https://www.ford-trucks.com/forums/a...poon-The-Tank?
Good Luck
Old 02-24-2006, 05:07 PM
mrc59's Avatar
mrc59
mrc59 is offline
You have a longbed, right? With a 38 Gal tank. If you can get 40 in a 29 shortbed tank, let's talk!
Old 02-24-2006, 05:21 PM
MobeyDick's Avatar
MobeyDick
3 long beds!
Old 02-24-2006, 06:57 PM
Btravelen's Avatar
Btravelen
Btravelen is offline
Does this 'harpoon' mod have any adverse effects?
Old 02-24-2006, 10:08 PM
refuse2's Avatar
refuse2
refuse2 is offline
Nope, none that I can see
Quick Reply: 32 gallons in my 29 gal. tank!
