Starter Burn out
Old Apr 16, 2001 | 08:32 AM
jspegg's Avatar
jspegg
Starter Burn out
I have a 390 in a 73 F100 and I have headers so I was just curious as to how you guys that have the same setup keep from burning up your starters all the time.I have burned out two since I have had the headers on,When ever I burn one up I just go get a free replacment from oriellys but after awhile their gonin to start asking question.Plus its not the easiest thing in the world to change starters when your running headers.But in the long run I would still rather have headers than manifolds.the manifolds break and crack to easy.
Old Apr 16, 2001 | 02:36 PM
mattb's Avatar
mattb
Starter Burn out
there are three ways to stop burning up your starters, first geta heat shield for the starter(easiest), or you could wrap the headers (tougher to do, headers need to be removed to do this.) this way also makes the headers rot out faster, because it traps moisture, last you could get a smaller high torque starter(pricey)
mattb
Old Apr 16, 2001 | 07:13 PM
pto dave's Avatar
pto dave
Starter Burn out
[font size="1" color="#FF0000"]LAST EDITED ON 16-Apr-01 AT 08:15 PM (EST)[/font][p]I used the doug thorley wheel-well headers. They work great and I have no starter problems.1972 Ford F-250 4x4!!!!Can change starter in about 5 minutes!!!!!
Old Apr 16, 2001 | 08:15 PM
FE427TP's Avatar
FE427TP
Starter Burn out
I haven't had any problems on my truck yet, and I've put on 15,000 miles or so over two years
Old Apr 17, 2001 | 02:02 AM
karljay's Avatar
karljay
Starter Burn out
I'd get the ThermTec starter wrap and then make a steel shield for the back of the starter. the wrap covers the body of the starter but leaves the back of the starter open. I took a sheet of galv steel and cut it to fit where I could cover all of the back of the starter and then drilled a hole and wired it to the header. This helps with the hot air blowing against the back of the starter.
Old Apr 17, 2001 | 10:37 AM
jspegg's Avatar
jspegg
Starter Burn out
How much did those headers cost?Do they sit far away from the starter
Old Apr 17, 2001 | 11:35 AM
weldman's Avatar
weldman
Starter Burn out
I've never had any problems with my Hedman Elite headers affecting my starter (knock on wood). My starter is just a cheapo rebuild too!
The headers sit like 2 inches from the starter and it is easy to change (like 2 minutes).
1978 F250 4x4 - 351M
Don't crush them, restore them!
Old Apr 17, 2001 | 09:24 PM
mnmfield's Avatar
mnmfield
Starter Burn out
I just put a CRV 4to1 starter in my pick up. I have Doug Thorly headders in a 76F250 390 C6 w/AC. I had to make pretty major modifications to the starter to make it fit and work properly. In my case the headder must come off to get the starter in and out. I personaly would go with a heat sheild on a good remanufactured starter if I were to do it again. Hope you figure it out. P.S. I got 5 new starters before they caut on to me.
Old Apr 17, 2001 | 09:25 PM
jspegg's Avatar
jspegg
Starter Burn out
I have heddmen headers but they sit about a 1/16 of an inch away there is just barley any space I have to jack my engine up to change starter
Old Apr 18, 2001 | 03:37 AM
karljay's Avatar
karljay
Starter Burn out
sweetlou1
Oct 23, 2013 03:42 PM
AlexKonya
Mar 26, 2008 06:32 PM
fastmover
N. California Chapter
25
Feb 3, 2008 01:27 AM
Chris_ce
Jun 12, 2005 02:03 PM
Jim McCarty
Dec 20, 2003 10:26 PM
