Headers burning up starter
Old Dec 20, 2003 | 01:35 PM
Jim McCarty's Avatar
Jim McCarty
I have a '73 F100, 390 CI, C6 trans, 2WD that has been warmed up with performance cam, Edelbrock intake and carb, headers, etc.. I have only about 1/2" clearance between the headers and the starter and have lost three starters in three months since installing the headers. Short of going back to stock exhaust manifolds, what can I do to preserve the starter. I have no objections to buying more expensive headers if they will provide better clearance.
Old Dec 20, 2003 | 01:41 PM
GeneStoner's Avatar
GeneStoner
Install a heat shield on the starter. Jeg's sells them or you can make one out of aluminum. I personally robbed some heat shielding out of a late model car's engine compartment and fabbed my own.
Old Dec 20, 2003 | 02:29 PM
fordfan428's Avatar
fordfan428
Wow, you have 1/2" between the starter and header??..I am lucky to have 1/8"..One starter in 50,000 miles, knock on wood, and no heat shield..Are you using the stock size starter or a mini?..A mini might help..If you don't mind spending the money on better headers get coated ones, heard it helps with the heat..Also go with the heat shield..
Old Dec 20, 2003 | 09:09 PM
stangman67's Avatar
stangman67
My mustang had about a 1/4" and it wouldnt start hot. I bought a heat sheild, pn THE-14150, from summit racing and it actually fixed the whole problem. I was surprised!
Old Dec 20, 2003 | 10:26 PM
Jim McCarty
Thanks for part number
That sounds cheaper than new headers.
FLgargoyle
Mar 3, 2014 08:42 AM
David LaPell
Jan 6, 2014 12:12 PM
BigBlockF350
Feb 22, 2013 02:27 PM
obey_your_master
Apr 19, 2007 06:01 PM
fling
25
Feb 26, 2005 08:16 PM
