Headers or Old Logs
Old Oct 20, 2013 | 02:03 AM
sweetlou1's Avatar
sweetlou1
Headers or Old Logs
This truck is a ’72 390 CS. It has 64K original miles on the original engine. Been told that if I do not intend to race the truck, then why invest in headers? Here in the desert, the engine will run hotter. The headers will burn up wires, cook starters, burn up the exhaust gaskets, and get exhaust leaks. Is it worth putting headers on this 390 or just keeping the old logs if it is just going to be a daily driver? I will have put an edlebrock intake, and edlebrock 4 barrel, along with the HEI , and dual exhaust. Just not sure if it is worth all the hassles for headers.
Old Oct 20, 2013 | 03:17 AM
skrudumra's Avatar
skrudumra
Hi! I'm New to the site. I have a 70 F250 with a 360 that I'm fixing up. Part of what I'm doing is increasing the power output of my little big block and part of that formula includes the installation of headers.
You mentioned the problems typically associated with using tube headers and for sure lots of us have experienced some or all of those. I also know that there are many things you can do to avoid all of those problems. Start by spending a little more on your headers. Don't buy cheap unless you figure on replacing them inside of ten years. Consider ceramic coating. Costs more but won't rust out. Heat shields and or thermal wrap will eliminate burning wires as will extra attention to routing. Buy locking header bolts to prevent bolts from backing out.
I want headers for my truck for the sound and performance.
Old Oct 20, 2013 | 09:00 AM
HIO Silver's Avatar
HIO Silver
Installed the combo last weekend.
Header time! Sanderson FF427
There is 1/8-inch between the starter and the tube. I'm pretty sure the starter can be replaced without undoing the header. It's close though...:
Aligns with the frame rail and projects about 5 inches from the cylinder head:
Driver side clearance from steering box:
Projects about 4.5 inches from cylinder head:
Old Oct 20, 2013 | 10:01 AM
sweetlou1's Avatar
sweetlou1
I am fairly new as well. I agree with what you are saying, just not sure if it is worth the effort. I can have done all those things as well and I thought about all those corrections. The engine wouldn't be pulled unless we had problems backing out the old bolts. Then we really screwed the pooch. Part of my "is it really worth the effort".
Old Oct 21, 2013 | 01:37 PM
JEFFFAFA's Avatar
JEFFFAFA
2X newbie skrud. I personally think the PINTA install will be worth it and appreciated by you once done. Sound,power in passing gear, probably a little better gas mileage,ETC. USE STAGE 8 brand LOCKING Header Bolts. You'll never have blown out header gaskets with them.
Old Oct 21, 2013 | 01:59 PM
skrudumra's Avatar
skrudumra
Exactly! That's why I say headers are worth it if you do it right. Most guys could slap on some cheap headers, beat the crap out of them to get them to fit right and be happy for six months until the problems started arising. If done right the first time, you'll never have a worry.
Old Oct 21, 2013 | 02:01 PM
CougarJohn's Avatar
CougarJohn
I doubt that you will be able to get the starter out without pulling the header but you will certainly bake the starter very quickly.
Old Oct 21, 2013 | 02:25 PM
skrudumra's Avatar
skrudumra
that's what heat shields are for!
Old Oct 21, 2013 | 02:26 PM
JEFFFAFA's Avatar
JEFFFAFA
2X John unless you either heat wrap the headers Or make a simple shield for the starter. The Sanderson's that are above in Hio's reply would not have these problems however.
Old Oct 23, 2013 | 01:54 PM
yetiman38237's Avatar
yetiman38237
Have a 1968 360 manual. Will full size headers fit?
Old Oct 23, 2013 | 02:05 PM
skrudumra's Avatar
skrudumra
Well when you buy the headers, always make sure that they are for your application. Summit Racing, in their parts description, has a check list that answers all of the questions concerning fitment to make sure that you're getting the ones made for your application such as: 2 or 4wd, auto or manual, floor shift etc. If your parts supplier doesn't offer this information, I would suggest calling them directly. Good luck!
Old Oct 23, 2013 | 02:49 PM
montana_highboy's Avatar
montana_highboy
You be the judge...
Exhaust.htm
Old Oct 23, 2013 | 03:02 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by montana_highboy
You be the judge...
Exhaust.htm
Montana. Man,dude,Good Job! I added this to my favorites. I can see me pasting this one a bunch in the future. When I do I'll give you the fame. You deserve it for finding this.
Old Oct 23, 2013 | 03:16 PM
montana_highboy
Wish I could take credit but I "stole" it off the FE forum years ago.
It is a very informative link though, so feel free to pass it along.
Old Oct 23, 2013 | 03:42 PM
HIO Silver's Avatar
HIO Silver
Bookmarked.
joel79ford
May 15, 2012 10:26 PM
73 ford guy
Offroad & 4x4
15
May 12, 2012 05:38 PM
ma94xlt
Jan 28, 2009 05:54 PM
bucks77ford
Dec 5, 2008 09:30 PM
Notthd
1997 - 2003 F150
May 29, 2008 08:35 PM
