Cutting the Cat
Old Feb 22, 2006 | 12:09 PM
Wittmer321's Avatar
Wittmer321
Cutting the Cat
When I install my stacks, I am considering removing the cat. Is this legal with emission standards, or are diesels exempt from these laws (specifically in NJ)? I know there was some talk recently about creating new emissions laws for diesels. Also, where is the best place to get the piping and clamps to get the job done? My kit for the stacks from Black Cloud came with an addaptor for 3.5", so that is the size pipe I'll replace the cat with. How do I couple the new pipe to the pipe in front of where the cat used to be?
Also, when I see the stacks with black smoke pumping out, how does that happen? Is that a result of a chip/tuner or lack of a cat? Whatever it is, it's bad ***.
Old Feb 22, 2006 | 12:45 PM
250turbo's Avatar
250turbo
not legal,federal law
Old Feb 22, 2006 | 03:36 PM
tjbeggs's Avatar
tjbeggs
its not legal but take a poll and you find many have done it. do you have a stock down pipe? if you do i would recommend replacing it and the expand you pipe right off that to 4 inch then into your stack system.
the smoke is unburned fuel by a truck with too much chip (fuel) for the air that is provided. while this looks cool i am not a fan of blowing unburned fuel into the air as is expensive to put in. now if i had 4 position chip and i could blown smoke everynow and then you bet i would but not all the time!
Old Feb 22, 2006 | 08:17 PM
Wittmer321's Avatar
Wittmer321
Does the DMV look for a cat when the do inspections? Or is it better to gut the cat instead of removal?
Old Feb 22, 2006 | 09:19 PM
dieself250's Avatar
dieself250
if the truck came with a cat from the factory then you might get away with out it or put an emty cat on, the ony diesel emmissions test in nj is a smoke test for trucks 18,000lbs and up, my 89 has duel stright pipes loud as all hell. they looked at it for 5 min then tested the lights and brakes then slaped on the 2 year sticker
Old Feb 23, 2006 | 11:50 AM
1969fordguy's Avatar
1969fordguy
I don't think it is legal to remove a cat. if your vehicle has to be inspected you should probably be stealthy in your modifications.
Old Feb 23, 2006 | 03:53 PM
pmasley's Avatar
pmasley
I would be very stealthy, especially in Jersey.
I got popped there last week for my straight pipe (warning for noise). Guess the cop did not like the turbo whine.
Old Feb 24, 2006 | 08:31 AM
1969fordguy
What kind of import loving 4 cylinder driving half a man wouldn't love the sound of a big 7.3L spinning the turbo???
Hmmmm, wait maybe he did like it! You only got a warning!
Old Feb 24, 2006 | 08:40 AM
94 1/2 stroker's Avatar
94 1/2 stroker
Why do our trucks (94-97) have cats and some of the early super dutys dont then the newer ones have a cat again?
Old Feb 24, 2006 | 10:02 AM
ckal704's Avatar
ckal704
I am working with Dale at Tymar right now putting togethr a new exhaust system. His recommendation: Replace the cat with a resonator. It is a hollow device that looks very much like a cat. Save your original. If you ever have a need to put it back on, you'll be glad you saved it because new ones are very expensive.
This is the gospel according to Dale.
Old Feb 24, 2006 | 10:58 AM
pmasley's Avatar
pmasley
I guess I really got his attention. I had it in low lock, granny gear and was pulling my uncles tractor (Rig) from the corner (where it broke down) to his house (1/2 block away). It was singing about 2,200 rpms. I imagine it was quite loud when that open pipe past his open cruiser window at about 5 mph. He was sitting in the middle of the block shooting radar.
Old Feb 24, 2006 | 01:52 PM
1969fordguy
You had to have gotten a picture of that! It puts a smile on my face just thinking about it.
I guess you went over the tow rating a little bit, huh?!
Old Feb 24, 2006 | 08:43 PM
otpracer100's Avatar
otpracer100
I live in NY and I asked a shop who does inspections today about the cat issue today.He told me if the truck was over 8600 gvw it is exempt from a cat,which is good cause "I aint got one".
Old Feb 24, 2006 | 10:06 PM
fishmanndotcom's Avatar
fishmanndotcom
here in GA all diesel are exempt from emissions. yes they come with cats but thats only to appease EPA
i love the south
-cutts-
2fifty
18
May 31, 2020 05:32 PM
97biostroke
Nov 27, 2012 10:44 PM
mstiles19
25
Oct 12, 2009 10:12 PM
bbull55
Mar 25, 2008 03:58 PM
thehickfarmer
Nov 14, 2006 05:51 PM
