My flywheel in my 67 Fairlane GT 390 4speed has many heat cracks. I found a used flywheel in good shape but it is out of about a 76 Ford Truck. They both look the same side by side but the one from my Fairlane is completely flat on the front surface. The other one has a very small step in it about 2 inches from the ring gear. Anyone know if they are interchangeable? Or can I tell if they are somehow? Of course I cant find a number on either of them..
Thanks any help appreciated
Yes everything looks the same except for the step. My machinest was wondering about machining the step off would this help with adjustment then.. So If we machine it flush will it interchange no problem.. Thanks alot I appreciate it.
Yup, should work fine. Are you going to put a new pressure plate on it?
If so, take your old flywheel, clutch plate and pressure plate, and bolt it together, on the bench. See what angle the fingers on the pressure plate are.
Now, assemble the new flywheel, clutch plate and pressure plate, and see if the angle is almost the same (fingers should be slightly more recessed with brand new parts because of wear).
If it's not, like the fingers are REALLY recessed compared to the original, the pressure plate is meant for the stepped flywheel.
Does this make ANY sense?
Again, been there done that
That makes sense. We will just machine the step off.
I will be buying new everything for the clutch . I will be sure to do that. I was hoping to be able to use this flywheel to save me some money a new one isnt cheap. This one I got for free. I really appreciate all the help..
