Internal or external balance?
Old Nov 17, 2010 | 12:48 AM
fairlane68's Avatar
fairlane68
I'm fixing to swap a ZF into my F-250, and the tranny came out of a '90 F-250. I assume I'm going to have to change the flywheel because the tooth count is different (using the '90 flywheel). I'm running into trouble with differentiating the difference with the flywheel for the '76 4.9, and the '90 4.9. Are they balanced different? Can I neutral balance the flywheel and be OK, or do I even need to? From what I can tell, the 80-up 4.9's are internally balanced, but I can't find anything on the 79-older 4.9's being internally or externally balanced.
Old Nov 17, 2010 | 06:57 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Inline 6's are all internal balance.
Old Nov 17, 2010 | 10:10 AM
AbandonedBronco's Avatar
AbandonedBronco
Yup, it's just the nature of the design. They're all internally balanced.
Also, just to double check, your ZF is for a small block, correct? (300, 302, 351). The big block / diesel won't work.
Old Nov 17, 2010 | 12:27 PM
fairlane68's Avatar
fairlane68
Yeah it's for a small block. Thanks guys.
Old Nov 17, 2010 | 12:39 PM
Rogue_Wulff's Avatar
Rogue_Wulff
If the 90 flywheel was from a 4.9/ZF combo, you might be better off using it, the factory clutch, and starter from the 90.
I'm not sure if the later ZF clutch/pressure plate would fit the early flywheel, without issues.
Plus, if you stick with the later flywheel, the clutch parts could be easily located by simply pretending the truck was a 90 when shopping.
Of course, the tooth count variation pretty much requires the later starter, and it's associated wiring changes.
One thing that also needs to be looked at. Pilot bushing/bearing *may* be different ID for the ZF compared to earlier trans types. It would really suck to discover the input shaft won't go in, after the rest of the clutch has been bolted on and you spend a few hours wrestling the trans around, just to go back and have to redo everything.
Stephen67
May 22, 2017 12:05 PM
Dannen
May 2, 2017 09:23 AM
F350moneypit
Aug 23, 2009 06:29 PM
76fordo
Nov 27, 2006 03:07 PM
alwaysfords
Nov 19, 2000 08:07 AM
