yes they do. but be prepared to order both of them. 4 55 gallon drums is the min order. so unless you want to go that far just use any 5w30 for the winter.
OTR Diesel Truck dealers & repair shops would be your best bet. A little birdy told me to tell you to check with a Volvo big-rig dealer if there is one near you.
I hope none of you are dumb enough to put this DIESEL RATED ONLY oil in any gas engine and expect it to survive. Might want to check the "product data sheet".
OK, I am totally lost as to what is the best thing to do for my 95 4.9L now. I have heard of people running Rotella-T or Shell diesel in their gas engines and having no problems. So what am I to do to keep this engine in top condition, other than redoing the valve train to run rollers or the like.
Some oil is rated for use in gasoline engines only, and some oils are rated for use in diesel engines only.
The oil you should be using is rated for use in both gasoline and diesel engines.
Now I know a bunch of you here are fairly sharp people. You tell me why you shouldn't use a diesel rated only oil in a gas engine. Dual rated- now that's okay but diesel only..........
Okay, hint #3
Look at the composition of the add pack and the allowables in the basestock. You are going to have to go back and read the spec sheet on this oil to see the difference.
