Oil & Lubrication
Api?
Old Feb 12, 2006 | 06:58 PM
wickymustang's Avatar
wickymustang
Api?
I know the right weight of oil that I need, but the question now is does the API rating matter? I have heard that my 95 F150 300 6cyl needs SJ or SI and nothing newer, any truth to this?
Old Feb 12, 2006 | 07:41 PM
scafes's Avatar
scafes
Just use the newest rating and you'll be fine. If what you are saying is correct, then there would be millions of cars and trucks on the road with the wrong oil!!! Oils keep evolving and are backward compatible, if that term is applicable anyway.
Old Feb 12, 2006 | 08:06 PM
ford390gashog's Avatar
ford390gashog
i don't remember SI oil. i don't think they made any. but there is some truth to your question. it is a good idea NOT to use API SM and newer in your engine. SJ and SL are best for yours. SM was the start of the new enviro friendly oils. they have a 60% reduction in ZDDP which your cam needs to survive. plenty of cam makers have issued notices about this. new cars don't need much if any ZDDP to live a long life.,
Old Feb 12, 2006 | 08:11 PM
okst1's Avatar
okst1
Nope, no SI. check this out
http://api-ep.api.org/filelibrary/AP...Guide_2004.pdf
Old Feb 12, 2006 | 08:13 PM
scafes's Avatar
scafes
Ford390. Got a serious question for you. How does one find oil then for older engines? I Have never seen more then one formulation of say Valvoline 10W30 on the shelf.
I am serious here, not questioning you, just want to learn.
Thanks. Matt
Old Feb 12, 2006 | 08:17 PM
ford390gashog
nice link! i gave you points for that!
Old Feb 12, 2006 | 08:23 PM
ford390gashog
well API SJ is still made by a few makers. But my source for API SL is diesel engine oil. it has a very robust add pack. Diesel engine oils are dual rated for use in gas or diesel engines. they are highly solvent and keep engines spotless. typical diesel engine oil is either 10w30 or 15w40 and comes in 1 gallon bottles. Rotella T , Delo , Delvac Super 1300 , Valvoline premium blue and Castrol tection are all fine examples of oil which will protect a older engine. we have been seeing a lot of cams go bad since the reduction in ZDDP came about. the ZDDP is what prevents the lifter and cam lobe from touching. without it you will get metal on metal contact which can cause flattened lobes. moly has been added to lessen this but moly only protects at high temp. so if the engine is never hot enough the moly does not come into effect. moly is very $$$ and some oil makers don't use it.
wickymustang
I am asking that too, since there has only eve been the newest ratings and never the older ones.
Old Feb 12, 2006 | 08:30 PM
scafes's Avatar
scafes
Hmm. So in other words I need to be checking into this a little more to find out what to use in my 66 Stang. I don't drive it much. Actually not at all. Yes that is a shame. I always read that the newer oils were always compatible with older engines. Would never have thought otherwise. Food for thought.
Old Feb 12, 2006 | 08:38 PM
ford390gashog
your 66 stang has a flat tappet cam. which needs lots of ZDDP to work right. SM oil is a early death sentence for the cam. if you had a roller cam you would not have to worry at all.
Old Feb 12, 2006 | 10:16 PM
TallPaul's Avatar
TallPaul
I believe SJ was the start of enviro-friendly oils insofar as reducing phosphorus goes. It would be interesting to find out when the "Energy Conserving" ratings began as that would be another of the enviro-friendly features. Yes HDMO will have a good additive package like pre enviro PCMO.
For a '66 Stang you could run the HDMO or get an additive for your PCMO. Also, Valvoline VR-1 Racing Oil has higher phosphorus, more like a HDMO, and is suitable for street use.
Old Feb 12, 2006 | 10:43 PM
ford390gashog
isn't the VR oil single weight? all the ones i have seen are.
Old Feb 13, 2006 | 02:57 PM
xtrford's Avatar
xtrford
What does the modular 5.4l have then? Roller or flat tappet cams?
ford390gashog
none of those. the modular is a OHC engine. it uses lash followers. very low friction
Old Feb 13, 2006 | 05:55 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
I thought that the SM formulation had substituted something else for ZDDP, in order to be "backwards compatible" and still provide the lubrication needed for the not so new engines.
Still though, I would think SM would be way better in all aspects than the SC-SE oils used by the older vehicles' back in the day.
