Oil & Lubrication
Api?
Old Feb 22, 2006 | 07:12 PM
  #31
rusty70f100's Avatar
rusty70f100
Ok smart ... . You know what I meant.
Show me a CI-4 rated 5w30 or 5w20.
Old Feb 22, 2006 | 07:14 PM
  #32
ford390gashog's Avatar
ford390gashog
the don't make one. the newest they make is SJ . shell makes it.
Old Feb 22, 2006 | 08:00 PM
  #33
wickymustang's Avatar
wickymustang
OK, let me get this one straight. Shell makes a SJ diesel oil that will work in my 95 4.9L? Both in a 5W-30 and a 10W-30?
Old Feb 22, 2006 | 11:46 PM
  #34
ford390gashog
yes they do. but be prepared to order both of them. 4 55 gallon drums is the min order. so unless you want to go that far just use any 5w30 for the winter.
Old Feb 23, 2006 | 09:16 AM
  #35
wavinwayne's Avatar
wavinwayne
Here's a CI-4 5w30 diesel oil
Old Feb 23, 2006 | 12:24 PM
  #36
rusty70f100
Interesting! Now where can I buy it?
Old Feb 23, 2006 | 12:56 PM
  #37
wavinwayne's Avatar
wavinwayne
OTR Diesel Truck dealers & repair shops would be your best bet. A little birdy told me to tell you to check with a Volvo big-rig dealer if there is one near you.
Old Feb 23, 2006 | 02:18 PM
  #38
99F150's Avatar
99F150
I want some of this Castrol too. sounds perfect for my Ranger 2.5L and my 87 Tbird Turbo with the 2.3L
Probley costs 10 bucks a quart?
Old Feb 23, 2006 | 04:14 PM
  #39
Flash's Avatar
Flash
I hope none of you are dumb enough to put this DIESEL RATED ONLY oil in any gas engine and expect it to survive. Might want to check the "product data sheet".
Old Feb 23, 2006 | 07:15 PM
  #40
ford390gashog
i thought diesel only oils had no cap on zinc or phos. what are the other differences?
Old Feb 23, 2006 | 08:33 PM
  #41
wickymustang
OK, I am totally lost as to what is the best thing to do for my 95 4.9L now. I have heard of people running Rotella-T or Shell diesel in their gas engines and having no problems. So what am I to do to keep this engine in top condition, other than redoing the valve train to run rollers or the like.
Old Feb 23, 2006 | 09:01 PM
  #42
monoman's Avatar
monoman
Some oil is rated for use in gasoline engines only, and some oils are rated for use in diesel engines only.
The oil you should be using is rated for use in both gasoline and diesel engines.
Old Feb 23, 2006 | 10:04 PM
  #43
Flash's Avatar
Flash
Why you would not want a diesel rated ONLY oil in a gas engine:
Hint #1
http://www.infineum.com/information/...r-sm-2004.html
Hint #2
http://www.infineum.com/information/...-ch4-2004.html
Now I know a bunch of you here are fairly sharp people. You tell me why you shouldn't use a diesel rated only oil in a gas engine. Dual rated- now that's okay but diesel only..........
Okay, hint #3
Look at the composition of the add pack and the allowables in the basestock. You are going to have to go back and read the spec sheet on this oil to see the difference.
Okay, hint #4
There won't be a hint #4
Old Feb 24, 2006 | 03:47 PM
  #44
wickymustang
So are Rotella-T and Shell diesel dual rated or diesel only?
Old Feb 24, 2006 | 03:49 PM
  #45
ford390gashog
they make both. simply look at the bottle it will say CI-4+/SL if its dual rated.
LFDavidson
13
Apr 17, 2010 10:50 PM
Beachbumcook
Sep 29, 2006 08:29 AM
Bob Ayers
Oil & Lubrication
Dec 24, 2005 02:34 PM
mybigredford
Feb 5, 2004 09:15 AM
sherm
Oil & Lubrication
Oct 14, 2003 11:02 AM
