transmission trouble
Old Feb 11, 2006 | 07:19 PM
bigpowerstroke's Avatar
bigpowerstroke
Unhappy transmission trouble
Today my dad borrowed the truck to tow a tractor and a skid steer. I thought it would have been a little too much weight but when I saw the small tractor I wasn't too worried. He had trouble with the truck after he stopped at a stop light. He said it felt like it just wasn't shifting. I checked the codes and this is what I got.
P0732 - Gear two ratio error
P0733 - Gear three ratio error
P0781 - 1-2 Shift error
P0603 - Internal Ctrl mod KAM error
What can I do to fix this? I've never heard of it so I don't know what to do. After we took the load off of the truck, it ran just fine.
Old Feb 11, 2006 | 07:30 PM
BlackSD250's Avatar
BlackSD250
could be as simple as a bad shift solonoid. If you have access to a ford factory scan tool you can manually control the solonoids and listen to see if they are working. If not you can pull the transmission pan an ohm out the solonoids although i don't know the specs off the top of my head. Hope this helps.
Old Feb 11, 2006 | 07:37 PM
bigpowerstroke
thanks, I have had my pan off several times, what do the solonoids look like, or where are they?
Old Feb 13, 2006 | 07:43 AM
BlackSD250's Avatar
BlackSD250
They are about the size of a C battery with a square frame. Easy to find just follow the wires. I believe they are all visible.
spinella
May 12, 2021 04:10 PM
Muscle Cars Blog
2004 - 2008 F150
Jul 9, 2013 12:11 AM
rmgionfr
Aug 2, 2012 10:11 AM
That_Guy
23
Mar 22, 2008 02:30 PM
bigpowerstroke
Sep 3, 2007 02:46 PM
