Sponsored by: Real Truck
trans trouble/have codes
Old Aug 21, 2010 | 07:05 PM
spinella's Avatar
spinella
a buddy of mine has a 2001 f250 7.3 4wd auto, with trans shifting troubles.seems to be hanging up some times he hooked up to his sct live wire and pulled these codes.
1. p0732 gear 2 incorrect ratio
2.p0733 gear 3 incorrect ratio
3.p0781 1-2 shift error
4.p0782 2-3 shift error
5.p0783 3-4 shift error
i tried a search but it did'nt work too good for me. anyone have a list of what these codes are? does it sound like a bad VSS?thanks in advance.
Old Aug 22, 2010 | 02:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Here is the list of what they are:
1.p0732 gear 2 incorrect ratio
But I don't understand why you asked, you posted the list!
These codes mean second, third, and fourth gears are not working correctly. Does the trans shift at all? Is the fluid burnt, or brown, or black? A bad VSS usually won't set these codes.
Old Aug 22, 2010 | 05:56 AM
spinella's Avatar
spinella
mark, thanks for the reply.i guess my question is whats the fix? it acted like this a couple of weeks ago and then returned to normal. then it acted up on wensday night. it doesnt seem to want to shift. i'm not sure about the fluid yet. i'm going to look at it today for him. obviously i was hoping for a easy fix. thanks again mark, i was hoping you would chime in.
Old Aug 22, 2010 | 10:53 AM
Mark Kovalsky
It might be an easy fix, it might not. The codes are only the first step to diagnose what's wrong. The shop manual (not Chiltons or Haynes) has step by step diagnosis.
Old Aug 22, 2010 | 01:49 PM
spinella's Avatar
spinella
do you have a shop manual? if so can you point me in the right direction? what should we be checking? thanks. also...fluid looks pretty good. full and still on the red side. he drove the truck this morning and it felt o.k. seems like when it happens,its will only act up when the trans fluid gets warm.
Old Aug 22, 2010 | 03:10 PM
Mark Kovalsky
I do not have a shop manual, sorry.
You can get one at Service Manuals, Owner Manuals, Wiring Diagrams, Service Bulletins - Helm Incorporated and I often see them on Ebay.
Old Aug 22, 2010 | 03:56 PM
spinella's Avatar
spinella
thanks mark.
Old Nov 8, 2020 | 03:44 PM
mws1569's Avatar
mws1569
Was there ever a fix to this issue?
Old Nov 8, 2020 | 04:18 PM
mws1569's Avatar
mws1569
this guy had the same problems mine is currently having. I wish he would have posted what fixed his issue
Old Feb 3, 2021 | 11:56 AM
SPEEDYGIXXER1000's Avatar
SPEEDYGIXXER1000
HI MWS1569, I'm having the same issues as well, did you find anything out with yours?
Old Feb 3, 2021 | 08:13 PM
mws1569's Avatar
mws1569
Nothing yet. My shop is supposed to have an answer soon.. if you figure anything out, let me know.. been over a year of these issues
Old May 12, 2021 | 04:10 PM
mws1569's Avatar
mws1569
Did you figure it out yet
The Masked Rider
Oct 27, 2020 07:56 AM
Rick Nielsen
13
Jun 26, 2020 06:44 PM
Rick Nielsen
Jun 13, 2020 09:44 AM
Nathan1982
Oct 15, 2012 06:00 PM
mwistrom
Aug 26, 2009 07:23 PM
